FS: Few things - Nokia 8250, Palm m105, Uniden Scanner, Dremel, Jigsaw
For Sale -
Just some stuff that is no longer required due to upgrading a new phone, palm, fixed scanner, etc.
Nokia 8250 (inc charger, battery) *SOLD*
Palm m105 *SOLD*
Uniden Bearcat 120XLT Scanner (inc Charger, battery & earpiece) *SOLD*
Dremel Tool + Carry Case *SOLD*
Dremel Flex Shaft Attachment *SOLD*
Bosch PST 53 AE Jigsaw
Stock R33 GTS-t Indicators
GTR Badge *SOLD*
3 x SDU Stickers (just collected, 1 White / 2 Silver)
Pictures of actual gear -
http://www.pbase.com/image/12015259
http://www.pbase.com/image/12015260
Palm m105
http://www.pbase.com/image/12015254
http://www.pbase.com/image/12015255
http://www.pbase.com/image/12015256
http://www.pbase.com/image/12015253
http://www.pbase.com/image/12015272
http://www.pbase.com/image/12015273
Dremel Flex Shaft Attachmenthttp://www.pbase.com/image/12015270
http://www.pbase.com/image/12015271
http://www.pbase.com/image/12015268
http://www.pbase.com/image/12015269
Open to serious offers. Will update with progress of offers.
For more information either PM or e-mail to [email protected]
Have received an offer of $175 on the Dremel .... so currently highest bids stand at -
Nokia 8250 (inc charger, battery) - $220.00
Dremel Tool + Carry Case - $175.00
If your interested in these or anything else, make a bid. I will leave open for 48 hours or until I'm happy with a bid.
Interested is good .... Cost $75 brand new and it's never actually been used (only opened the box to take the picture) Reason for selling is because I havn't used it, just brought it with the dremel and now that I don't really need to dremel for what I used it for (brought hole saws) I don't have a need for it lying around.
Been offered from $15 - $30 so far :( What were you thinking ?
It's the highest bid at the moment. I'm leaving open until Tuesday just to see what comes through though if that's ok, otherwise it's yours !
Bids stand at -
Dremel Flex Shaft Attachment - $35.00
X, Yep ... These retail for $298 or there abouts these days. Included is the rechargable battery, charger, earpeice.
Even at 50 % you're looking at $149 ... It's in perfect condition and hardly used, I'd be lookin at around 67 % of current retail.
You are quite right, it provides nine-band VHF/UHF coverage including Airband, 100 memories, and super fast Scan and Search features. Covers 66-88 MHz, 108-174MHz and 406-512MHz.
Also pre-programmed if your in Sydney :D
Bids stand at -
Dremel Flex Shaft Attachment - $40.00
*NEW* GT-R Badge - $25.00
Bids stand at -
Nokia 8250 (inc charger, battery) - $220.00 pickup
Dremel Tool + Carry Case - $175.00 plus postage
Dremel Flex Shaft Attachment - $45.00 pickup
*NEW* GT-R Badge - $25.00 plus postage
Palm m105 - $100.00 plus postage
Uniden Bearcat 120XLT Scanner - $150.00 plus postage
Bids stand at -
Palm m105 - $110.00 plus postage
Note to all ... these items are advertised on Performance Forums, Overclockers Australia and Skylines Australia ... bids can be made by PM, e-mail or on the thread .....
Bids stand at -
Nokia 8250 (inc charger, battery) - $220.00 pickup / SiXX OCAU
Dremel Tool + Carry Case - $175.00 plus postage / Rustla PF
Dremel Flex Shaft Attachment - $45.00 pickup / Kosti OCAU
*NEW* GT-R Badge - $25.00 plus postage / George SAU
Palm m105 - $110.00 plus postage / Scraperage OCAU
Uniden Bearcat 120XLT Scanner - $150.00 plus postage / Matt West SAU
Listing the user and forum they are from to help you guys out with any misunderstandings ...
Bids stand at -
Palm m105 - $120.00 pickup / niSSSan PF
Bids now stand at -
Nokia 8250 (inc charger, battery) - $230.00 plus postage / zac OCAU
Palm m105 - $135.00 plus postage / Scraperage OCAU
Not long to go ..... :D
Now updating all bids in replys as they come in to keep you up to date with the action as it happens -
Bids now stand at -
Palm m105 - $140.00 plus postage / Tomee PF
The Palm is slowly climbing ....
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
