there not all in melb, but here is a few; enjoy.
Drift line
21 Thornycroft St, Campbellfield 3061 Victoria
Phone 0425855540
www.driftline.com.au
D1 Garage
120 Mooringe Ave
North Plympton
Adelaide, Sth Australia
Ph: +61 8 8294 1355
www.d1garage.com
Garage-13
Metz Automotive through Eddie on 9544 4274
Clayton (1364 Centre Rd).
www.garage-13.com
Just Jap
Address
101 Bath Road Kirrawee
NSW Australia 2232
Phone
(61 2) 9545 0532
www.justjap.com
EKW
44-80 Hampstead rd
West Footscray Vic 3012
03 9274 4413
www.ekw.com.au
Ichiban Performance Imports
13 Cunningham st Moorebank NSW 2170
02 9600 7066
www.ichiban.com.au
Import Spares
2 Sleaford rd Windsor Gardens SA 5087
08 8266 0212
www.importspares.com.au
Japanese Motorsport
2 Rosberg Road, Wingfield SA 5013
08 8260 6919
www.japanesemotorsport.com.au
Jap Performance
6 Kelso Crescent, Moorebank NSW 2170
02 9601 6715
www.japperformance.com
Rolin Imports
31 Central Drive Andrews Gold Coast QLD 4220
07 559 8533
www.japparts.com.au
www.driftbitz.com
SSS Automotive
6/120 Gilba Rd Girraween NSW 2145
02 9636 1278
www.sssautomotive.com.au
STZ Automotive
1/15 Landy st Northgate Brisbane QLD 4013
07 3630 4455
www.stzautomotive.com.au
The Toy Shop Auto Imports
38a Enterprise Dr Beresfield Newcastle NSW 2322
02 4966 2233
www.japimports.com.au
Central Victorian Auto Parts
Kialla - Auto Parts Recyclers
Address: Melbourne Road
Kialla, VIC, 3631 Telephone: 03 5823 1911
Asian Auto Spares
198 Kingsford rd Slacks Creek 4127
07 3208 0133
http://www.asianautospares.com.au/
Unique Autosports
Unit A3/2A Victoria Ave Castle Hill NSW
Australia 2045
(02) 9634 8000
http://www.uniqueautos.com.au/
Hey guys,
Need to know of skyline wreckers in melbourne. looking for a series 2 r33 front bar and can't seem to find a wrecker that stocks them.
dude
there's a guy selling the front bar for cheaps ...
check this out
http://www.skylinesaustralia.com/forums/in...opic=100617&hl=
cheers,
Rob
  • 1 year later...
new shop opened in somerton. Suchhh goodd pricess i tripped out. Owner said cos there new there selling stuff dirt cheap to get a good name. They had pretty much every import nose cut and half cut you can find.
Anyway think there called NG Jap world wreckers
In fleet st somerton
from memory i think there number 34 or 35.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
