hi everyone. I was thinking about going to the drags tonight for a bit of fun and was wondering if buying an octane booster to drop into the petrol tank would give me any sort of power gain. i have a previous best time of 13.8 with the same mods as i have now, would half a second off be possible, or would the difference be minute? thanks!
https://www.sau.com.au/forums/topic/101759-octane-boosters/
Well no difference in power but my tuner recommends adding a bottle if I was to do a 1/4 mile run or a dyno comp just for the assurance of no detonation, it all depends on how much power your running I suppose.
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1866553
There was a thread with this asked a while back.
I uploaded a Zoom article where they tested 20+ octane boosters, only one allowed any extra ignition timing.
Might need to run a search if you want to find the article.
Basically they do bugger all and are a waste of money.
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1866555
try adding toluene
you will have to advance the time drastically though
and yeah, it can take a toll on your car if you push it to hard
it burns alot hotter than petrol
I have been dropping 8L of it into my tank and advancing the timing to around 40 degrees
but yeah, it does give significant gains
just dont add to much
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1871845
As most people have said - not for power gain - more for insurance. Raises the anti-knock value of the fuel - protection against detonation.
Fast Fours Magazine did a test ages ago with NF Octane Boosetr Racing Formula and Nulon Pro Strength Octane Booster tieing for first place.
Both raised the RON value by 2.8 points.
https://www.sau.com.au/forums/topic/101759-octane-boosters/#findComment-1872090
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
