I've got a weird issue with the rb25det Im running. The motor was just rebuilt with wiseco/eagle combo, and arp headstuds, with cometic gasket. The car is running an HKS 2540. When the motor was stock, before the rebuild, it was running 19psi (1.3 bar). With the rebuild on the car, if I try to run more than 16psi (1.1 bar), the car will "buck" and "breakup" all the way through the powerband. I would like to run UP TO 22psi (1.5 bar) on race fuel. I tried putting in race fuel thinking that it could be engine knock and timing getting pulled, because on the dyno plot, as soon as the higher boost level (more than 1.1 bar) comes in, the the car not only "bucks" but the power immediately drops down like the stock ecu is pulling timing. However, even with the C16 (117 octane) it still did the same. The car is making good power, even at only 1.0-1.1 bar, but I wanna run more boost. I've checked the plugs, and they are fine, and tightly gapped. I've also checked for vacuum leaks, and the system pressure tested fine. Could a bad coil cause this...? What else could be causing this problem? Just to let you know, Im using SAFC and adjustable fuel pressure regulator for fuel control, and the air/fuel ratio is perfectly flat at 11.8. Any ideas or suggestions would be greatly appreciated. Thanks again!
https://www.sau.com.au/forums/topic/101981-boost-problem/
Has anyone had problems with tuning with SAFC at power levels of 300rwkw or more? That's about where I'm at right now with this thing, but I need to be able to run more boost. Bad coils are the only guess I have at the present moment, so I'm at a loss. It's pretty much a misfire, but at very low boost levels. Anyone else experience anything similar with their car?
Edited by SleepingTalon
https://www.sau.com.au/forums/topic/101981-boost-problem/#findComment-1871037
maxing out the stock airflow meter will simpy mean you drop the bottom load point on the maps, so it will still work youll just loose accuracy as once you goto 5v your tune map becomes one dimensional
https://www.sau.com.au/forums/topic/101981-boost-problem/#findComment-1873066
Well, it's like a misfire. So Im not sure what that could be. The plugs are tightly gapped, and the only thing I can think of is that a coil could be going bad. Any ideas of what that "bucking" or "miss" could be? I wasnt sure if the car would do that if the AFM just started missing "airflow counts" or what it would do.
https://www.sau.com.au/forums/topic/101981-boost-problem/#findComment-1873543
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
