I'm purchasing a 180sx pretty soon and theres already have 3 that I have my eye on all with turbo upgrades, car no.1Blitz K3
2Trust TD06
3HKS GT2530
which of the above turbos produces the most HP and which unit is best suited for the car?I appreciate any opinions you guys can give. :roll:
https://www.sau.com.au/forums/topic/102-turbo-peoplelisten-up/
I don't know about the first one but the TD06 is comparable to the HKS2835 which is a decent unit.[/quote:d2908a54a0]
Yeah, but doesn't the TD06 come in different sizes?do you know if it has an external wasgate?The details of the 180 with the trust turbo is as follows;TD06,HKS cams,HKS frontmount intercooler,550cc injectors,GTR fuel pump,Chipped computer,drift pipe.You think u could take a guess of what the HP would be? :?: :wink:
https://www.sau.com.au/forums/topic/102-turbo-peoplelisten-up/#findComment-2585
blitzpower, as far as I know the TD06 has 14 different models. Some come with an actuator and some without.
The 2835 has 26 different models with the A/R ranging from 0.64 to 1.12. There's a turbo there to suit nearly every application.
With the mods the 180 has you could have anything around (most likely over) 300hp at the whels. This is my guess though, so take it at will.
https://www.sau.com.au/forums/topic/102-turbo-peoplelisten-up/#findComment-2586
Details of the second 180 is as follows;HKSGT2530,HKS frontmount intercooler,550cc injectors,Z32afm,Apexi SAFC,HKS EVC IV.
So what do you think guys? which of the two cars would be the better buy and with the most HP? :?: :?
https://www.sau.com.au/forums/topic/102-turbo-peoplelisten-up/#findComment-2589
The prices for the 180s are 1.Trust-$20k
2.HKS-$22k
Which out of the 2 would have more low to midrange power(the cars haven't arrived from Japan so I really can't do a test drive just yet)
I'm looking for a "[b:1b907d14f0]sits you back in your seat[/b:1b907d14f0]" type of car.......u know,the rush thing :lol:
https://www.sau.com.au/forums/topic/102-turbo-peoplelisten-up/#findComment-2592
the hks car will build boost from a lower speed but the trust car you will be driving along happily and they the boost will hit and you will be flung back in your seat @ around 4k rpm may be more
Btw my r32 does this and its auto at 5k rpm on the dyno it jumps off :-)
ah such problems cant wait till the manual box and bigger turbo go in
make sure the body is good in the one you purchase.
meggala
https://www.sau.com.au/forums/topic/102-turbo-peoplelisten-up/#findComment-2593
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
