Hey people
I recently got a set of 19 x 8 inch rims on my R34. Now the tyres are 235/35/19 all round, and have an offset of +35 which is the same as stock. The wheels were balanced etc, but when they were put on it was discovered that a 2mm spacer was required for clearence of the front brakes due to the shape of the spokes and big ass R34 front brakes. I also put them on the rear just so all was even. I have now found that at speeds over 100kmph a get a shake in the wheel, sometimes it is only slight, other times it is pretty violent.
Do you think that becasue the wheels/tyres were balance for the +35 offset, that with the spacer bringing it down to +33 the balance is out of wack and is causing the shakes. Should i get them rebalanced and get the tyre place to attach the spacer to the machine when they balance them?
As a side note, i have not had a wheel alignment since i have had the new wheels put on, could this be causing the problem?
Any advice would be great.
https://www.sau.com.au/forums/topic/102085-steering-shake-with-new-rims/
Although I would definitely get the wheels aligned (to ensure the best possible handling and even tread wear) I can't see this being the primary source of your vibration. Particularly if the only thing that has changed are the wheels and there was no vibration with the old ones.
It sounds as if the problem lay in the wheel balance and/or the spacers potentially affecting the state of balance.
Although this may sound silly, have you checked the wheel nuts ..... is it possible that the wheel(s) are loose?
the car is also lowered around 3 inches but this was happening before the lowering.
I don't think it is the wheel nutz as this happened from the word go. As in i got the car back from the shop on saturday afternoon (lowered with the wheels refitted, and drove out to mallala on the sunday and it was doing it. So the wheels would of still been very tight then. Wheel nuts do come loose with spacers but this is usually when it is a 10mm spacer type thing. It is not overly common on a 2mm spacer
Thanks for your input though much appriciated
It's either a slightly bent spacer or the stick on weights have come off straight away. Couldn't possibly be the wheel itself or the tyre. Balancing without the spacer wouldn't matter because like you said you have a spacer on every wheel. I'd also suggest getting a wheel alignment straight away, because i'm sure you don't want to be buying fresh tyres just around the corner!!!!
Have them balanced on the car, which will take the rotating assembly including spacer in to account.
As others mentioned, wheel nuts would have been my first point to check.
Just as a side note, the spacers are not legal, which you may or may not know or care.
chops
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
