Hey all... has anyone got any comments?
600 x 300 x 80 Fmic
3 Inch exhaust dump back.. standard cat
Stainless exhaust manifold
Gt 30 with vg30 rear
Walbro pump
Sard fuel reg
Standard computer
Standard injectors
Iridium plugs
any thoughts?
https://www.sau.com.au/forums/topic/102129-r33-auto-gt30-dyno/
they leave it in second cause it will go to redline without trying to change into third early.. but the gearing of second is prob only a little lower then a manual third
What gear is typically used for an auto on the dyno?
the lean spot at the top is the rev limiter..
Based on what I have seen, rev limiter = rich, not lean.
Regardles it can't be on the rev limiter from 90 kph to 110 kph.
My guess is the injectors are maxing out. Based on your PM, the fuel pressure at 50 psi plus boost is quite high, maybe the Walbro fuel pump can't handle the pressure and its flow is dropping off. That needs to be checked next time on the dyno.
:rofl: cheers :)
Edited by Sydneykid
I didnt get a print out from the dyno showing when the boost was coming on etc, but i know it was only running at 13 pound to make 228kw, and from driving it i would say just over 4
The dyno graph looks like a fairly straight line so it obviously isnt surging or laging to badly.. i think 40kph on the graph is around the 3000 rpm mark.. i dont know if that helps... i could prob go back to the dyno and get the other print out if it will help..
can you tell me what the lag is like? I have a GT30 with a VG30 rear too..
Full boost in second at 4900rpm..........
GT30 with VG30 housing (700177-5011) TO4S 7 blade wheel
Nismo 550cc Injectors
Walbro 220lph Fuel Pump
FMIC (600x300x75)
Full 4 inch intake
powerfc and Datalogit
Q45 afm (90mm)
Full exhaust thats huge, hi flow cat
95ron fuel
220rwkw, and 470nm of torque at 15psi
Full boost in second about 4800 - 5000
Full boost in third about 4500
Full Boost in 4th is about 4200
Fitting a RB25 Standard exhaust housing to it on the weekend. I think the VG30 may have been ground out too much.
Edited by The Mafia
it can't be,  the lean spot is the tuner backing off the throttle, hence going to a lighter load point, also why the power drops off..
It's lean before it gets to that point.
I had the Walbro. Doesn't seem to flow very well up high. Ditched it.
Same problem i had with my walbro :w00t:
he why its being used as a lifter pump rather than a main pump.
Very crappy things the walbro's.
I was from 12afr's into the 10's with just a fuel pump change and nothing else.
so what are you running now?
and if its a external pump where did you mount it.. cheers
Same problem i had with my walbro  :)
i just went and picked up my other dyno sheet showing the boost...
Damm gizzmo ebc... cheap and nasty... set on 13psi
but it dosent hit 13pound till 6000rpm then dies again.. grrrr...
anyone have any suggestions on smothing out the boost line?
makes good power at 7000rpm at only 12 pound.. hmmm B)
they do it in the gear which is closest to a 1:1 ratio. so im told.
they did mine in 3rd(left Overdrive off)
IMO that PSI reading is weird
mine goes straight up to what its set using a $22 controller.
doesnt fade off untill 5,500-6000rpms
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
