i have been told that i need new castor rod bushes and also need new castor rods
my question is this
i already have new whilteline castor bushes here at home and was going to buy these
http://cgi.ebay.com.au/FORGED-CASTOR-TENSI...1QQcmdZViewItem
would it just be easier to guy these
http://cgi.ebay.com.au/NISSAN-SKYLINE-R32-...1QQcmdZViewItem
the nismo ones look a little different to the newer ones so that why im a little confused. and id also save a little bit of money on the nismo one because they already have the bushes...is this correct?
Edited by DLuded
https://www.sau.com.au/forums/topic/102394-caster-rod-help/
I don't like the look of the cap screws supplied with those cheaper gerneric brand castor rods (first link). You should also take a look around on the fourms, there is a lot of negative info on Castor rods with spherical bearings as well.
https://www.sau.com.au/forums/topic/102394-caster-rod-help/#findComment-1888373
  • 3 weeks later...
If your after performance and adjustability i'd go with the first link no bushes needed just the two bolts through the control arm and castor rod (either side) then a wheel alignment. Or cheaper get the second link arms and replace bushes (good as new but no adjustment).
Good luck
https://www.sau.com.au/forums/topic/102394-caster-rod-help/#findComment-1943195
get fully adjustable pillowball rods
heaps better
BETTER? Not if it's used on the road regularly
Much more NVH
Higher likelihood of cracking the front subframe due to lack of compliance
Sphericals wear out rapidly as they have no dust/dirt/water protection
Good quality spericals are costly to replace
Breakage is not uncommon
Illegal in most states
Maybe for a track car only, even then they are illegal for most classes of circuit racing.
:P cheers :D
https://www.sau.com.au/forums/topic/102394-caster-rod-help/#findComment-1954608
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
