Item: 180sx. ca18 turbo. auto
Item Condition: very clean, straight body. neat interior. gun metal grey paint. sr20 style front bar. tinting. otherwise standard.
Reason for Selling: bought as a mint donor car to do a rb conversion but ended up buying a 180sx with rb25 already done.
Extra Info: engine is partly pulled apart (nothing major: turbo, manifold, piping, etc) but still in the car. will sell the whole lot or as a rolling shell and keep engine for datto conversion or the like. also (to avoid confusion later) its my mates car and i'm selling it for him.
Price and Payment Conditions: sold
Contact Details: prefer pm
Edited by rb20inside
https://www.sau.com.au/forums/topic/102596-180sx/
for the rolling shell? ca18det engine/ auto box cost round $800? so probably round $6k?? mate has final say, as its his, but would probably be keen for round that.
come and have a look if you live in brisbane area. ring or pm me for my mates phone number to organise further if your keen.
https://www.sau.com.au/forums/topic/102596-180sx/#findComment-1893037
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
