Hey pshht did you get your car from aussie car compliance?
those photos looked like it was parked outside their garage,
i just bought my car of joel, hes a pretty cool guy, picked it up on the 28th,
was it you that put a scratch in your rim when you were reversing out of hes garage?
Yeah got it from aussie car compliance in castle hill. Joel is a good bloke. The scratch was very minor, hardly noticable at all. Getting it fixed for $50 in a few days. So what did you get? Any pics?
The rims are Buddy Club P1 Racing 18x8 and 18x9 with 225/40 and 255/35 rubber and it sits on NPG Coilovers. Im happy with the stiffness of the suspension, definately the best handling car i have driven. Virtually no body roll, very predictable, takes bumps and crap very nicely, etc etc..
Hey everyone
Well this is my first Skyline, its an r33 gtst series 2.
I just sold my Soarer, so its going to be good to see what Nissan has to offer :)
These are the photos of it not long after it reached here, picking it up on friday.
Dude i want one!!!!
Where did you get it?
Hey everyone
Dude i want one!!!!
he got it from aussie car compliance, they're one of the sponsers for SAU, go to www.aussiecarcompliance.com.au
has photos of all the cars there and also prices
heres the pic, i ended up getting the auto one which was more suited to my budget,
but the one you end up getting is one sweet ride, it had so much mods on it already and he practically sold it as stock price, love the 18inch wheels, i want those GTR seats
  • 1 month later...
i know this is an old thread, but i'm looking into getting a similar R33. And it was posted that Aussie Car Compliance is in Castle Hill, but on their website it says they're in Ermington??? Am i reading this right? If they are located in Castle Hill what's their contact details?
Thanx everyone
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
