Hey all,
Car is going into the workshop on Monday...
Turbo will be removed and sent down to GCG for my Highflow :D
Jaycar gear should be on the way very soon as well...
Highflow is costing me $1500 due to a slight sponsorship as well ;)
:D Muahahahaha :D
https://www.sau.com.au/forums/topic/103074-finally/
Aaaaaaaaaaaaaaaaaah no, just the turbo, stock tubo goes hard, and with my pfc I could really use the highflowed to it's full potiential, it'll be just a waste putting it back on yours...... :D jk
I wish I had the funds to highflow, will eventually :D That is the only thing really left to replace on my beast :D
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894500
Yeah I dont have funds either.
Thats where parents come in :P
Dads giving me $1000 to get he rest of the stuff done etc.
HEEEELLLLLLO Long lost BROTHER! Can Daddy buy me a highflow as well thanks? :(
Great to see you have parents who are so supportive, and can afford to be!
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894646
how did you manage the sponsorship? are you putting stickers on your car or something?
Yea basically. Just got in contact with them, things I was planning on attending etc. So yeah, in exchange for a sticker :(
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894683
HEEEELLLLLLO Long lost BROTHER! Can Daddy buy me a highflow as well thanks? :P
Yeah well I basically paid for the whole car etc etc by myself. And now I need their help, so yeah, good folks :(
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894691
Chris, are you taking your car to a workshop? Is it just the turbo you're removing and replacing at this stage?
I'd say do it yourself if you have the space, time and tools (or get your hands on a basic toolkit). Removing the turbo is pretty easy, and replacing it when you get it back isn't much harder, if at all...
There are some fiddly bits and some tight gaps, and a digital camera will come in handy if you think you'll forget where stuff goes, but it's all good and helps you learn. And if you don't have to pay someone to do it, as well as store the car in the mean time, then it's money in your pocket which can be later spent on more bits or further tuning... ;)
Or maybe, if you mean "workshop" as in dedicated area where you can do the work yourself, then you can just ignore me and carry on as above...
<_<
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1901266
There are some fiddly bits and some tight gaps, and a digital camera will come in handy if you think you'll forget where stuff goes, but it's all good and helps you learn.  And if you don't have to pay someone to do it, as well as store the car in the mean time, then it's money in your pocket which can be later spent on more bits or further tuning...  :D
<_<
Yep to an actuall workshop... Dont have enough time really to do it myself, and they will be installing the IEBC, DFA and a Mixture Display as well
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1902338
Geeze man, best of luck with it *envious*
What boost will you be running?
Are you going to fork out $150 for a Fuel Pressure Regulator?
Or injectors?
Youve got the exhaust(?), GTT 'cooler, & the new bits, all tuned together.
What power output are you expecting?
Id imagine with a FPR you'd be able to reach 180awkw at ~14psi fairly steadily.......
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1902832
Or injectors?
1. With the two settings, Probably 10 psi and 15psi
2. On the books Brendan :) Will come with time...
3. Yep, So Fuji Catback, IEBC, DFA, GTT Cooler, HKS Panel. I'm expecting once tuned to reach the 180awkw mark as you said. Then add the FPR, GTR Fuel Pump and a Split dump pipe.... Should reach the magic 200awkw. Which is where it shall stay :D
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1902990
how much are they charging you to install and calibrate the IEBC, DFA and mixture display?
(...mixture display, is that like an air / fuel ration gauge?)
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1919358
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
