Here are the parts, all are available separate and are negotiable. Everything works, is in good order and is cleaned and ready for you.
The RB30/25 is already sold.
Speedo, Tacho and all that jazz (showing very low kays) - $50.00
A/C "radiator" (I think its called a condensor - the thing that sits at the front) $40
A/C compressor, lines and all that stuff (no gas of course) $20
Heater box from behind the dash $20
Ashtry (with woodgrain for some reason) $whatever you like
RB25DE Computer . $40
Full R33 2 door dash with vents (no cracks, looks fine) $50
Glovebox $20
Surround for cluster $20
Kick panels (both sides) $20
Steering arms from both sides (with stock suspension in good nik - no leaks) they are 4 stud though) $100
Induction pipes/air box (whole thing) (suits turbo car or NA) $100
RB20 AFM $80
Radiator in A1 condition (no bent fins - same as a turbo one) $50
All plastics from around the front of a 33 (wheel arches and splash gaurds and stuff) $20
Brake lines (all of the metal ones) $20
Also have a VL N/A head, enjoy that as your new boat anchor!!! This is free to a good home .
Any questions you can PM or mail me.
***Also I have two RB20 turbos.****
One is a genuine low kay Rb20 turbo thats never been overboosted, the other has a chipped blade....
Good one - $150
"bad" one - offers around 50ish :D
https://www.sau.com.au/forums/topic/103186-r33-leftovers/
Just after the air conditioning line from the compressor to the front condensor cylinder.
pm me
delivered to 2486 :rofl:
Also lower rear left hand control arm if you have it.
https://www.sau.com.au/forums/topic/103186-r33-leftovers/#findComment-1914092
pm me
Hey mate,
No worries, I've both those bits and will pm you later on. :)
https://www.sau.com.au/forums/topic/103186-r33-leftovers/#findComment-1914982
All pms answered :)AFM is 100% working, and only out as my car uses a AFM'less map.
Its got about 75,000 kms on it, is clean and I'll refund out if it doesn't work :P
https://www.sau.com.au/forums/topic/103186-r33-leftovers/#findComment-1921596
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
