here is the selection of seats that Garage Thrash had on display at TAS.
I think these two would be perfect for Troy so he can fit in with the strange folk in Melbourne (funky monkey in particular)... lol.
pfft Troy has no chance of fitting in here unless he's got the seats on the rack above with the leopard skin... and even then only if he's dressed in nothing but a loincloth in matching fabric.
about $22 AUD and a rocking good time. I have drunk my fair share of those in japan.
the 1.9litre kirin beside comes with soda bulbs and you can buy and attachment that turns it into a mini keg, complete with drip tray and everything.
the also sell asahi in every other size imaginable. from the 3 litre cans, right down to 135ml cans! and every thing in between (small bottles, longnecks, regular cans, 600ml cans, 1 litre cans etc etc).
ok well if you are into trying new things you should try the following. (these pics are from 05 TAS but gave me a giggle then, and may give someone a giggle now).
first pic is straight face, best behaviour (well except for my hand placement)
Second pic, not such good behaviour...
and again, same story (just not as good looking model!)
appologies for the old pics, but i was looking for that kirin keg attachment pic and saw these. happy memories.
i should get someone to make a gif out of one of those pairs for me. or learn how to do it myself.
for those that wanted some drift pics, i don't have any from this year as it was raining, and snowing the 2 weekends we were there. last time i went in the rain i couldn't get warm for about two days afterwards, and I broke a video camera filming the drifing for a bout 3 hours in the rain.
here's a pic though of me with some very wet japanese street drifters.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
