firstly can i say what a fantastic forum, information on here is priceless.
im a gts owner from across the water in the UK and very impressed with this set-up . and reading through learning stuff i never thought id learn.
i posted this same topic on the uk owners club, but the response i got was very poor and im hoping maybe yous can help me out
bought this from ebay.
its in excellent condition apart from this one sided crack.
im planning on repairing it myself ( hopefully ).
can someone or everyone offer my advice on how to, what to do etc etc.
this is the first time ive ever tackled this, and being as brave as i am, my next purchase is a bumper thats needing similar patching up.
i dont believe in paying a body shop to fix something im sure i can manage myself with a bit of time and effort.
https://www.sau.com.au/forums/topic/103344-body-work-maintenance/
plastibond!
Don't know whether they have it over there, but for that sort of smallish job, that is what I would be using. Its basically a two part epoxy (I think!) paste that you mix up, and it hardens to a fibreglass type strength.
After that you can get the sandpaper out and smooth it out, so that it follows the original angles.. bit of paint and nobody would know.
I've used it to repair small cracks in front bars, and its much easier than using fibreglass for small work.
Yeah my answer to everything like thast is BOG lol BOG it up and sand it back then paint it, i'm not fimilar with Plastibond, but predator makes it sound like its a better bet. Bog is what they use to patch up crack dings in basiclly your body kit (hopefully not all over your car LOL)
But yeah bog is really easy to use, once again its 2 parts, its liek 1:50 and you only add a tiny bit of hardner, it goes of in a few mins so you only mix a little up at a time and then you will be sanding for a while LOL, Bog sets like concrete and is what i would use if i was in your situation (only cuase im fimilar with it, not saying it's the best method)
I hope it helps
Michael
Bog is a product used by panel beaters. Ive used it to make flairs on a RX7 S1, and its a very very easy product to use.
All as you need to do is sand back the area lightly to remove the paint, make sure there is so oil or dirt where yrou goign to bog, so clean it up. Then once you mix the bog, as i said its two parts, you got you putty, then the hardner, mix it up, it'll say on the packet what coulour it shoudl go, then jsut smear it into the crack with a scraper or ne thing really, smooth it out as best as you can on the out side, then leave it 10 or so mins to dry, and start sanding back the bog untill you get the shape you want.
As for sandpaper yeah wet and dry will be fine, use a normal gritt one to take the paint work back, but use a heavy grit for takeing the first few layers of the bogged area you have just done, once its getting down to the shape and leveling out with the other plastic, use a finer grit so you get a smoother finish, then last set is jsut painting.
It's very very very easy, you will be fine.
Bog is basicly an automotive putty, that sets like concrete.
Hope i'm of some help.
Michael
ah bog will be what we have as "body filler" over here?
http://www.diytools.co.uk/diy/Main/Product...ProductID=11889
thanks michael, youve been a great help. hoping to get started on it tommorrow.
but one final question ( please dont think im daft ), would i be best to remove the mesh before i start this?. its just the screws holding the mesh seem a bit rusted and it may be tricky. but im half saying to myself, "dont be lazy, do this right and remove the mesh, dont skip bits, do it properly".
That looks like the stuff, i just had a 5kg tinn LOL and a tube of hardner, you only need a little bit however.
As for the mesh:
Too tell you the truth by the looks of the picture you don't really need to take it off, i mean the crack are on the out side and the mesh doesnt' really get in the way, however it could become a problem when respraying. You can leave it on if you want.
Personally what i would do, is take it of, either buy new stainless stell mesh if you want silver or stick to what you want, replace the screws with stainless steal so the new ones don't rust, or if its black grill, just paint the stainless ones. Also if you take the mesh back you can easily sand back the "whole" grill, giving it a complete respray, then replace the grill back on with either the old grill or new grill, and new screws.
Thats what i would do.
Be sure to post pictures of your work.
Michael
Edited by Michael_1882
BOG is just polyester resin loaded with a filler like calcium carbonate( talc ). To get the best adhesion to do this repair it would be best to use straight polyester resin. Just check the back of the grill and see if it aint ABS plastic as well. If its ABS or fiberglass youll be ok with the polyester resin for the repair. Just wash it with soap and water and then clean it with acetone to prep the surface before you start the repair. To get polyester resin and hardener go to fiberglass repair places like boat shops or swimming pool places. Follow the instructions and youll do fine
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
