Hey, my friend has an R33 GTS-t and is about to install the following mods. He wanted me to ask here roughly what sort of power figure he should expect. Now I know all dyno's read differently but all i need is an estimate as to how much power he will be making, as he is very sure his car will be quicker than my 220rwkw S13 Silvia and I really don't believe it will be.
This competition will be sorted out properly at the drag strip at Calder Park...
His mods are:
exhaust from front pipe back (stock dump still)
FMIC
Pod
HKS Step 1 Cams
Nismo fuel pump
Nismo fuel reg
Bleed valve at 12psi
His mods are:
FMIC
Pod
HKS Step 1 Cams
Nismo fuel pump
Nismo fuel reg
he will make about 180rwkw no he wont beat you BUT if he installs an ecu and a proper dump pipe you will get beaten.
almost a Vs thread :P
Without an aftermarket ECU or air converter eg SAFC he might even be lucky to get that 180rwkw.
Weird order to do the mods IMO - i would have thought cams would be at the very bottom of the shopping list.
And yes, at Calder you will have his car for breakfast.
Edited by Beeble
Check the dyno thread please. This thread really isnt required.
The results for stock turbos are in there, as are the 100's of other posts on this topic of stock turbo'd R33/dyno results.
And no, unless you cant drive, no way a sil will be slower than a R33 mainly due to the large weight difference
Yes, its a very weird order to do mods. He brought some Nismo 555cc injectors too, but you can't install these with the stock computer, right?
He doesn't want to upgrade the turbo yet, but if i were him I would of brought a Power FC and maybe exhaust manifold instead of the cams and injectors.
R31Nismoid: Sorry dude, I didn't realize the dyno thread was there, thanks for the info.
Coolio :P
Will give him some turbo upgrade ideas for later on down the track too :D
He will need an ECU for the 555's.
And yeah, i agree, PowerFC would have been a "better" first option instead of cams
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
