There are 4 channels for where the water is ment to go down if it gets past the rubber seal,
(1.) if 1 of the channels is blocked, water will come into the car. You should be able to see the channels with the sunroof open on all 4 coners. You need to get an air gun, to clear the channel(s)
(2.) the clannels rubber hose could have come off the channels itself, which means roof line has to come off!!!
Im in denial that my sunroof will ever leak :(
Id hate to think, but your only choice may be to pull it out, and refit a new rubber. It may have to be a factory rubber too...
It is no "factory rubber" for the sunroof,if u want new rubber, you'll need the glass and rubber.
so if (2.) the clannels rubber hose could have come off the channels itself, which means roof line has to come off!!!
does that mean i need to replace the rooflinee?
IF, the rubber hose has come off the channel(s), no u don't need to replace the roofline, just need to get it off, to be able to get to the channels.
