Ok i got a 1993 Series 1 R33 Skyline, RB25DET. So far ive got POD with CAI, Hybrid front mount intercooler kit, cat back 3" exhaust & soon Splitfire DI coil packs.
I want this turbo T3 T04E
Specs:
57 trim front wheel in .60A/R compressor cover housing.
.64A/R rear exhaust housing that requires a external gate.
I have a standard manifold etc, i want to know what i need to change, i was talking to someone and he mentioned cause it was externally wastegated i would need new manifold, intercooler piping, dump pipe & of course a external wastegate.
I want to know what exactly i will need to bolt this onto my car and what size wastegate i will need etc.
https://www.sau.com.au/forums/topic/103751-questions-about-t3t4-turbo/
why is there an actuator on that first shot? Is it Journal or ball bearing? Oil or water cooled?
I'll try and help you out with what you need.
manifold with wastegate connector. Pipe to connect intercooler plumbing to the turbo. Wastegate. Split dump pipe, probably custommade. Oil lines, water lines if water cooled, gastkets and some kind of elctronic management. Then there might be the other supporting mods you need like fuel pump, bigger injectors and maybe a fuel pressure regulator.
The turbo looks like one of those that you can add an integral gate to. maybe this is a cheaper option
^^^what cameron datto said, you can get an internal gate hks turbo that bolts on and will be of better quality.
theres lots of supporting information on the forums regarding old school t3 to4 turbochargers and the modifications you will need to make it work, its not just as simple as plonking it on and driving away. given its external gate you'll also need a suitable manifold and wastegate.
lets not forget
aftermarket ecu
aftermarket injectors
aftermarket airflow meter (z32 or q45)
3" split dump at the very least with 3" front pipe and 3" hiflow cat
some good tyre
some good suspension
heavy duty clutch
and then prepare for lag, as that wont make anything exciting until i would expect say 4000 rpm ?
Thats the Turbo i bought yesterday of ebay (top pic).. i got the one with internal wastegate ... if you can afford better id advise spend the extra and buy quality,
in my case its a fairly short term need as sounds like mine could be farked n i jus dun have a spare couple grand right now so its (hopefully) a bargain.
Ill post up when i recieve it and its fitted to let you all know what there like
Lee
Hmmm, I am looking at getting a new turbo for mine (got the stockie on still). Basically i want it so thaty i can safely pt the boost up to 12psi.
I want more power but not the lag associated. Ie boost @2500 - 3000
I have been told by some that t3t4 is the way to go but im sure this is wrong.
What type/brand turbo do u guys reckon is the way to go?
Edited by Taso84
