Hi,
Just picked up my R34 a few days ago. Just wanna know if i should upgrade the security system in it and if so which one to go for? I think the alarm thats in it is a Cyclops alarm/immobiliser. I dunno if i should be spending $$ to upgrade it(if it can be upgraded) or put the $$ to somewhere a lil more useful like gettin more Hp :P
https://www.sau.com.au/forums/topic/103852-security-system/
Whats your budget for an alarm (if you can put a price on security B) )
I got a Cheetah 777 installed for $500 in June last year. Has all the usual tricks with entry and engine immobilisation plus it won't arm itself if you are near the car with the transponder (working on the car/@ petrol station) and it will arm itself if you forget to press the button and walk away.
There are many on the market, it comes down to preference and what you want it to do....
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1910574
Well i would assume that the alarm i got which came with the car has at least 2 points of immobilisation, i think thats the min standard. Which 2 im not sure. And it's probly got a glass break sensor as well which is the most common, i know there isn't any extra microwave devides. Whether this is sufficient im not sure, just tryin to get an idea of wot u guys out there have got. Ive heard of security systems that will let u know (via mobile) if ur cars alarm is goin off, no idea how much they would cost tho.
Im also plannin to get a turbo timer soon and im not sure how this will work in conjuction with the immobiliser which cuts in 30secs after u leave the car. Any thoughts?
Thanks for the reply Topaz.
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1911873
The guys at Action Alarms integrated my turbo timer into the alarm as well :P. I am not sure whether this was an extra feature from the lower models or not.....
Very clean install as well, I would recommended them
Action Alarms
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1913640
I got my system from Action as well, I have a key pad as well as tilt sensors, alarm, immob and all the other fruit.
I highly recommend them.
You have more chance of hearing of a break in, into fort knox then my car going walk about.... Between the Doberman, the 12 gauge the alarm and me sleeping in the back seat they have buckleys!!!!
Mike
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1920497
These were option upgrades with the Cheetah 777 that I got. I might go back and get them soon :)
You also get a fridge magnet telling you to go back in a year for a checkup of some kind
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1920852
Nice... i also noticed TKO tinting in there Topaz, r they a good mob to use for tint? For some reason the R34's come out std with the back quarter n windshields glass tinted but not the fronts. So i gotta get just my 2 front windows done, shouldn't cost much i imagine??
R those guys mobile as well?
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1928050
No, shouldn't cost much, my R32 GTR is the same with the rear quarters done :)
last I saw was $245 for the entire car to get tinted
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1928067
My car was the same, Rears and Quarters tinted and not the front, I went to tint a car or something..... Ummm business colours are red and yellow.....Arh F*ck it, you know who I mean. Cost me $ 120 for both which was pretty good.
And they matched the colour for me.
Mike
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1928817
Mike
Did they say what grade it was? like 35% which is the darkest legal!?
So your rear screen was already tinted? was that from the factory or previous owner?
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1934796
Don't want to Hi-Jack the thread, They didnt tell me the tint ratio and I didnt ask, if that kinda makes sense...Wink Wink Nudge Nudge.... All I know is the guy at the pits when I was re-registering here in WA, said he wanted to put the light gun on it too be sure, we ended up talking about my drive across the country, Guess he just plain forgot!!!!!
Wether the tint is factory or not is unclear, I am the first owner here in Oz...... I think it is law or something over there that only the rear and quarters can be tinted, Somebody please clear this up for me, as i am not 100% on it.
Mike
https://www.sau.com.au/forums/topic/103852-security-system/#findComment-1934901
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
