old wheels!
New wheels, Ok well, they are not that fab. They are just stock R34 GTT wheels without the centre caps. For now the caps are on, but i like it without the caps. Ill find something to cover the hub as i think it looks tough. $550 for the four, in damn good condition.
Wrapped in 225/45/17 Hankook Ventus K104's (my first new set of tyres) $165 each fitted and balanced
Now, only to lower the front 1 or 2 circlip grooves, castor/camber bushes/rear dust covers and a wheel alignment and i am...DONE with suspension :)
When/If in future i decide to get new wheels, Advan Racing RG's in gold, but for now the standard wheels will do. I think silver or gold suits a white car well!
Will let everyone know about improvements over the next few days, maybe we should have a stagea specific tyre thread as we do carry around a few 100 extra kg's then skylines?
https://www.sau.com.au/forums/topic/103899-wheels-anyone/
  • Replies 50
Posted Images
Actually, there where a few different wheels on the R34.. On my R34 GTX I've got the (factory standard) AVS 5 spoke ones (8 inch rims), not the standard nissan 6 spoke ones that Alex now has.. I'll put a pic up soon (I'm in the middle of shifting the web hosting of my sites...)
Ian
Edited by ian
https://www.sau.com.au/forums/topic/103899-wheels-anyone/#findComment-1910312
Wow AC, great value for sure, for that price..... geez! Ive been 'looking' for R34 GTT wheels, but couldnt find anything for anywhere near under $1000.
So, Stagea owners, if you hear of some R34 wheels for sale for a 'decent' price, please let me know (if you dont want them that is).
Thanks in advance, Brendan
https://www.sau.com.au/forums/topic/103899-wheels-anyone/#findComment-1917909
  • 4 weeks later...
$600 for 4 x R34 GTT rims with rubber
I paid $650 to have them fully bubble wrapped etc.
Also (work is) paying $95 via TNT to have them delivered from NSW to Adelaide
from Stan (Satanic).... thanks man! Heaps good to deal with!! :O
Brendan
Edited by Tangles
https://www.sau.com.au/forums/topic/103899-wheels-anyone/#findComment-1987391
siick :)
they are nice wheels for sure :)
Cheers, yeah Im real glad I saw the add from Satanic maybe 5mins afterhe posted them for sale. LOL
Pretty sure I will have the rubber taken off, 1 rim repaired from gutter rash, and then head to our business's powdercoaters for a gunmetal grey powdercoat finish, I think.
Then save for new tyres, so it wont happen too quickly (my wife just got robbed today) due to cash constraints, but thats neither here nor there I guess.
https://www.sau.com.au/forums/topic/103899-wheels-anyone/#findComment-1987824
