Item: R32 GTST skyline parts. Prices added :D
ad to clean up the shed so make an offer on these parts.
i can drop parts off if needed.
contact Justin ( 07 5540 7735 ) 0401-027-348
Engine ECU, to suit auto comes with plastic kick panel. (will work in a manual car)
Full set of coil packs.$ 100 Sold
RB 20 engine cover. $ 50 Sold
Complete dash loom. $ 200
Dash cluster surround with all switches $ 80
Complete stereo surround with side covers. $ 100
Glove box $30
Center ash tray $ 15
Inside & outside fuse covers.$ 10
Brake booster & mater cylinder with front discs $ 350
Origional washer bottle with motor. $ 20
Complete heater box. $ 100
Set of caster arms with good rubber bushes. $ 150
Complete set of struts with springs shocks.$ 250
Power steering resivour with lines and hoses.$ 100
windscreen wiper motor and wiper arms. $ 80
stock intercooler piping $ 100
Steering shaft uni joint.$ 10
passanger side Air vent$ 10
drivers side air vent $10
Under dash panel, goes across stering colum $10
Oil cooler $ 40
charcol canister with all lines. $20
Auto brake pedal with mount bracket $ 20
turbo Heat sheild $ 40
Air flow meter with lines and hoses that run to turbo.$ 40
Edited by just32
https://www.sau.com.au/forums/topic/104015-for-sale/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
