Hey biatches !
My rocker cover gasket leak has finally gotten to the stage where it is leaking onto the manifold so I had better do something about it.
Question: Where can I got one from to suit RB20DET? Should I gen nissan or will another one suffice ?
Thanks. :)
https://www.sau.com.au/forums/topic/104291-rocker-cover-gasket/
yeah and u will probally be better off replacing both gaskets, meaning both rocker covers, cos if one is gone i'm sure the other is on its way too. dam i didn't think there were 40...
dude do it urself and save the cash, just disconnect all that top L bend inlet crap, undo all those screws/bolts and pop the thing off. clean it up, put new gaskets in the groove that it sits in and put all back together. There is a particular order to put those bolts back in to ensure its evenly done up, was in the skyline workshop manual if remember correctly.
Hopefully these 2 images make sense. Its of my VIN of when my car used to be a RB20DE, and i'm sure its the same with RB20DET.
PS: Just found my reciept, and confirming i only needed 20 rubber washers.
gaskets were 29.57 each and washers 42.80 all up plus 10.19 tax coming to 112.15 in total from garry rogers nissan in glen waverley. Also those part numbers mentioned on that FAST screenshot are same with on the reciept.
Edited by skypy12
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
