  • Replies 306
Posted Images
YAY, I am so happy that funky was able to deliver so quickly after my payment, he is the best trader that i have ever ever delt with and was soooo soo good with communication that i want to have his babies.
now I'm getting a bit worried about you Alex.. :rofl: Oh, sarcasm! :rofl:
As Gwen Stefani put it....
What you waiting
What you waiting
What you waiting
What you waiting
What you waiting for
What you waiting
What you waiting
What you waiting
What you waiting
Tick-tock, tick-tock
Take a chance you stupid hoe
i think the fact he is a moderator in other sections (especially the for sale one) is pretty f*kt up, and warns of potential scammers hehe, sounds familiar to me. i reckon every single member who has paid and got nuthin should email or PM Prank the forum owner and let him know and ask for his moderating privilages to be removed if he treats forum members like idiots.
i am currently waiting on a copy of the stagea rb25 ecu pinouts in english as well, plus a couple of other very handy wiring diagrams for abs, etc. few days and i should have them for sure. im paying good money for these but i need them to finish my wiring off.
how about some fellow eastern staters go round and give funky a house visit and a friendly reminder that he owes about 14 different people money or a CD each :thumbsup:
cruiseliner, when you get the stagea RB25 ecu pinouts are you willing to share?
dunno yet, considering im paying for them and then everyone else wants them for nuthin, if others pay for other sections to veiw ill possibly do a swap for another section, as im getting it from the new zealand website that translate manuals, and its $5 a section, so buy some other diagrams i havent got and ill swap for sure :thumbsup: slowly everyone will build up more and more info on stageas then for a quarter of the cost of buying all the manual pages myself.
guys, the manuals were sent out last week. You should have them by now. Please PM me if you haven't got them with your addy so I can double check they were sent to the right place.
Here's the ECU pinout. image is blurry, I'll see if I can upload a clearer pic.
The pinout is for a series 1 RB25/RB25DET ECU. Were you guys after the Series 2 one?
hey funky that series 1 pinout is very helpful, except can u please post up the rest of the pin descriptions for pin 67 upto pin 124 as they must be on the next page.
hope u can help as i need it asap to finish my ecu wiring off. hopefully the cd arrives soon too and i can check abs wiring etc too.
could u put up a wiring diagram of the attessa (ETS) ecu pinouts (same as ABS ecu i think) as well pleasse :P
thanks
Brad
series 1 and series 2 are almost identical except the series 2 has a couple of extra pins that are used. so that r34 english diagram tells ya pretty much every pin and what it does :P
found the 3 wires from the engine ecu to the attessa ecu.
pin 5 - tachometer drive signal (blue/white)
pin 37 - throttle opening signal (purple/white)
pin 43 - sensor ground (orange/blue)
finally after 12 months of hunting i have some reliable info on the pinouts :D
Edited by CruiseLiner
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
