  • Replies 306
Posted Images
YAY, I am so happy that funky was able to deliver so quickly after my payment, he is the best trader that i have ever ever delt with and was soooo soo good with communication that i want to have his babies.
now I'm getting a bit worried about you Alex.. :rofl: Oh, sarcasm! :rofl:
As Gwen Stefani put it....
What you waiting
What you waiting
What you waiting
What you waiting
What you waiting for
What you waiting
What you waiting
What you waiting
What you waiting
Tick-tock, tick-tock
Take a chance you stupid hoe
i think the fact he is a moderator in other sections (especially the for sale one) is pretty f*kt up, and warns of potential scammers hehe, sounds familiar to me. i reckon every single member who has paid and got nuthin should email or PM Prank the forum owner and let him know and ask for his moderating privilages to be removed if he treats forum members like idiots.
i am currently waiting on a copy of the stagea rb25 ecu pinouts in english as well, plus a couple of other very handy wiring diagrams for abs, etc. few days and i should have them for sure. im paying good money for these but i need them to finish my wiring off.
how about some fellow eastern staters go round and give funky a house visit and a friendly reminder that he owes about 14 different people money or a CD each :thumbsup:
cruiseliner, when you get the stagea RB25 ecu pinouts are you willing to share?
dunno yet, considering im paying for them and then everyone else wants them for nuthin, if others pay for other sections to veiw ill possibly do a swap for another section, as im getting it from the new zealand website that translate manuals, and its $5 a section, so buy some other diagrams i havent got and ill swap for sure :thumbsup: slowly everyone will build up more and more info on stageas then for a quarter of the cost of buying all the manual pages myself.
guys, the manuals were sent out last week. You should have them by now. Please PM me if you haven't got them with your addy so I can double check they were sent to the right place.
Here's the ECU pinout. image is blurry, I'll see if I can upload a clearer pic.
The pinout is for a series 1 RB25/RB25DET ECU. Were you guys after the Series 2 one?
hey funky that series 1 pinout is very helpful, except can u please post up the rest of the pin descriptions for pin 67 upto pin 124 as they must be on the next page.
hope u can help as i need it asap to finish my ecu wiring off. hopefully the cd arrives soon too and i can check abs wiring etc too.
could u put up a wiring diagram of the attessa (ETS) ecu pinouts (same as ABS ecu i think) as well pleasse :P
thanks
Brad
series 1 and series 2 are almost identical except the series 2 has a couple of extra pins that are used. so that r34 english diagram tells ya pretty much every pin and what it does :P
found the 3 wires from the engine ecu to the attessa ecu.
pin 5 - tachometer drive signal (blue/white)
pin 37 - throttle opening signal (purple/white)
pin 43 - sensor ground (orange/blue)
finally after 12 months of hunting i have some reliable info on the pinouts :D
Edited by CruiseLiner
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
