  • Replies 306
Posted Images
Hi guys I havnt read all of this thread as I only have net acess via my iPhone as I'm away. However I run a media business and we do cd/DVD duplication and printing, ect ect.
So if disc form is needed I can do multiple copies.
Let me know via pm if you are interested.
Shouldn't cost too much and easy to post.
Cheers
Well we really should NOT be discussing pirating Nissan Intellectual Property dudes! I would not be interested in selling this information at all and do NOT wish to go to be visited by any form of police! I am sure SAU dont want any trouble either, so can we please stop discussing this in the open?
  • 3 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
