For those people that are interested...a blockage in rear oil feed line caused the turbo failure in "twoogle". This is a common fault and we are currently producing a braided upgrade kit to rectify this problem occuring again.
A GT-RS upgrade is the way we are going and we will be able to compare 2530 vs GT-RS dyno graphs. This has been a hotly debated topic in the past and due to the fact no other changes are being made to the car will be a realistic comparison. Will post up dyno results when available.
Paul and Stacey
DiRTgarage
  • Replies 40
you just need practic
is a 4 hour job each way when you do it a few times
and i dont even know what im gdoing
Dont worry Pete....someone is trying to be cheeky....but your right...i quote 8hrs too. Nissan quote 12hrs.
Id like to sit and watch the 5hr R&R and see every bolt replaced and no leaks or fu(k up's. But who am i to question the master mechanic Mik....The guy who doesn't need practice cause he's SEEN someone do it fast. Given enough beers ive SEEN ugly chicks become hot too!
Edited by DiRTgarage
Id like to sit and watch the 5hr R&R and see every bolt replaced and no leaks or fu(k up's. But who am i to question the master mechanic Mik....The guy who doesn't need practice cause he's SEEN someone do it fast. Given enough beers ive seen ugly chicks become hot too!
Have you had a bit of practise Paul? Last I heard, it was 16 hours R&R for you. I would dig up the post, but I’m sure you have edited it, as all of your posts seem to be edited at some stage…
Yes, I have seen it done in 5 hours, by a guy at one of your favourite workshops. And there were no leaks and no ‘bolts’ left off…not that there are many to put back on. But yeah, it’s an 8 hours job allowing for a bit of contingency…definitely not 16 though!
Oh…and I’m no ‘master mechanic’ I didn’t spend 5 years busting my guts at uni to work on cars for a living, that’s for sure.
I have a tomei stroker kit in my engine but i don't tell anyone cause i can't run the times or make the power. I also constantly go on about how heavy my car is as an excuse for my poor ET's
really...well that is a revelation...I think that may be the only honest thing i think you have ever said.
Paul and Stacey
DiRTgarage
paul can i ask would do you think was the cause of the blockage?
and can i ask the type of oil you were running at the time (if you dont want to post it pm please as i'm very interested) as when i worked in Engine Reconditioning industry we sent a number of oil sample for testing and discovered that one praticular oil brand had caused numerous engine failures.
I wish you the best with the GTRS turbos as you have done amazing well with the 2530's , i look forward to see the results between the two as i so nearly bought a set but was put of by the bad rep the coped at one stage and the awesome results i had gain from the garret gt2560r.
pete
ps 9sec low mounts (THATS THE SHIT)
pete
Hi Pete,
After speaking to a few guys today in the industry it seems the standard design of the oil feeds aids this problem...its the feed which has the loop in it. A 3mm orifice inside the tube and the bending of this tube that is done on an upgrade (yes i may have contributed in the failure) makes the feed smaller in diameter are two factors involved. Also the oil that sits in the bottom of the loop on shut down gets exposed to a lot of heat (small volume of oil and extreme heat). The question im asking myself is "is this why std rear turbo's always fail"? is the heat and oil starvation to blame as much as the ceramic wheel?.
For years i was a Mobil 1 user...but the last year or so i use Castrol Formula R, and change oil and filter before every meet. Which means the oil would see 500klm tops before changing.
A larger orificed plumbing system in braided line will replace all water and oil feeds and drains with the upgrade (earls will make a killing out of me). I will design and produce the kits for sale after testing to help prevent future failures in other vehicles....how many ppl rip of the turbo's on an upgrade without checking these lines...i know i am guilty of this myself so i can say it would be a lot.
Target is 9's on the low-mounts and with the full interior being installed back in the car, a 9 sec pass will be awesome.
Hi Pete,
Bel Garage have been using braided oil feeds on GTR's for years...it also makes R&R of turbos much easier...and yiu need all the help you can get...
Incidently, I checked my factory lines when I had them off and they were spottless.
Interesting to note that about the stock lines Paul.
It might help to know it cost me about $400 in braided and speedflow fittings with converting the 25t to tt. The fittings tend to be the killer but it was about $10 for straights from my local hose place (HIS Hose Somerton in Melb)
Guest
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
