  • Replies 48
I cant believe how full of "it" some people are!
AND... I cant believe what I am reading!
There is nothing wrong with and never will be anything wrong with modding an "ageing" car and anyone who says that it is a money pit or a time sink is kidding themselves!
eg:
*R31 Aus spec 4 door average purchase price $3000 - $5000 for a good one.
*R32 Gtst Import - $10000 - $16000 for a good one.
*R33 Gtst Import - $16000 - $21000 for a good one.
*R34 GTT Import - $24000 - $30000 for a good one.
Consider those prices as a stock car purchase (no mods) now...
I know R31's and if anyone wants to argue that point PLEASE DO!
A good R31 RB25DET conversion can be done for under $7000 I know because I did one!
As for the brakes and suspension - The brakes dont need major upgrading unless the car is going to see track every now and then just a good set of High temp pads and slotted rotors is enough plus the obvious things like new fluid, wheel bearings and mabye a caliper rebuild, all up - under $1000.
Suspension - Bushes $500 for a full set of urathanes - Fitted, Lowered springs $150 an end and shocks $200 an end.
As for engineering ($600 at the most) - you shouldnt have problem passing it with those mods as long as nothing has been done "bodgy" and the car is road worthy.... Once again I know because I have done it!
All up if the cars exterior is in good condition which isnt rare you shouldnt need to do much else to it apart from maby service or rebuild the diff - $750.
SO - For uner $14000 you will have a VERY nice R31 with ALOT of sleeper apeal and it will be great to drive (and it will upset alot of V8 boys from the lights).
Where as if you buy a later model like a 32 and put an RB25DET in it you will have already spent at least $17000 buying the car and front cut.
So Gus If you want to do it then BLOODY WELL DO IT!
People said that I was an idiot for building my car but look at what it is today and the benifit of it all is that not every joe and his dog has a modified 31 (unlike certain other Skyline models).
Oh and Gus - If you need help with any Parts or work at all let me know cos I can get anything for very cheap (which means it will all be cheaper again) and there is nothing I cant do to a 31.
There Ive said my piece....Now i sit back and wait for the fall out.
Yayyyyyyy!! congrats Gus!!
Getting your first car is the best feeling ever
Yes, it is a Box R31 but hey, its all mine thanks to my brother and his generosity. it's a stock, auto,  white executive, with one flat tyre.
generosity of your brother? is he giving it to you?! :P
eg:
Shut up mick.
Anyways I forgot to mention gus young lad, I will give you a hand with any work you need help with!
Oh and R31 coupes are cooler so lets weld the back doors! :lol:
Hey Gus, i've got plenty of spare parts if you need any to borrow to get over rego... Just ask Bluprint/Mark about my stock :mellow: I'm in tuggeranong as well, from the sounds of it you are as well.
And... Go all out on mods, don't buy cheap shit here and there and plan a bigger upgrade later. Just get the top range stuff and regret it later.
Edited by StinkyPoo
yeah stinkypoo i see you on R31 club, your silo is nice.
at the moment, ive gotta get rego check and see what needs doing with what, then do myself a little write up of my finances and stuff, see if i wana put some money into it and have me a nice first car, or if i wana save my money and go for a really nice car by the end of the year!
and yes shell he did give it to me :P
eg:
HA! remind me again why you want to up-grade???
pfff, as if weld doors to make it look like a coupe, 4door AUS spec is where its at -i sold my gt passage so i could go aus again!
good stuff gus, dont let anyone tell you its not worth doing up, and btw, 300 000kms on a RB30 engine is NOTHING. u got at least unuther 200 000, probly more.
-Tom
Edited by kossak
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
