Hey guys and gurls.
SORRY ITS NOT THE GETRAG, but something tuffer.
Are you looking for a serious gear box that can handle up to 900hp (yes that what there running off these in the states in stock form). TUFF hey? Yet to hear anyone beaking them yet to. Mainly used on the Vipers :(
Well i have what your looking for... 1 6speed tremec gearbox. Brand new, never been used.
Bell housing can be made to fit most makes an models, I was going to be using it behind a SR :P Should be good for those 500 - 800hp GTRs getting around bracking boxes..... Or anything else for that matter.
These boxes retail from the $7000 mark and up. If you can find one!!
Asking $5000 ono
DREAMERS CAN BASH OFF
Craig.
Edited by SXER32
https://www.sau.com.au/forums/topic/104995-closed/
Some information would be nice.. maybe some pictures.. than maybe people won't be so critical of you..
where my mach got it from and what cars its from.....
something there.. just doesn't.. quite match up..
Edited by Links
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1933550
OK boys and girls, just got of the phone with a nissan dealer that is also a dealer for nismo and even if it is the same as the R34 GTR (which it maybe, i could be wrong). He couldnt give me a exact price, but said that theyd be selling around the $6000 mark new + shipping from japan.
So if this box is the same, $5000- $4500 is a dam good price.
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1933719
mate good luck with the sale, if someone really wants they will pay that amount and then again if you really want to sell it you will drop your price. The gen 3 gear boxes go for around 3k and there a t56 (6 speed) also the zf gear box i now for sale going for 4.5k so if someone wants it they will pay it. But judgeing by the previous coments your probably waisting your time here.
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1933869
You still cant clarify EXACTLY what it is.
Do you seriously believe that someone will pay $6,000 to you, when you dont know for sure what your selling yourself and you cant even confirm for certain what sort of box it is?
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1933983
well i thought there was only one type, but i was wrong. ill get some pics and more info on the box.
I dont know alot about it cause, my mach wanted to use it on my drift project which was going to make around 500hp atw. And he tracked it down an got it for me. And i trust him over most people cause of the years, exp and training he has.
sorry to sound like a dic bout it. You learn something new everyday.
Craig
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1934060
Correct me if i'm wrong but wouldn't it be cheaper to get a PPG set up for this price?
And again people correct me if i'm wrong but wasn't someone selling a Trust or HKS dog box for about the same price a few months ago?
I'd rather a PPG gear set for that price.
EDIT: Why would you buy a 6 speed for a drift car? Just curious.
Edited by MADGT4
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1934255
Well yes apparently R34 GTR boxes arent as strong or similar strength to R33 GTR boxes which you can pick up for just over a grand or so. Anything to make a buck I guess.
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1934880
Ok been and looked at the box, and im wrong in that its a tremec 6spd out of the latest HSV and GTs, and they also do run these in the vipers in the states. If you where to buy new from dealer itd be $7000+. IF you can get one. And the tremec is from what ive been told stronger that the getrag?
So sorry for the miss-comunaction. Should of looked first.....
Will be taking pics of it next time im at mach. And price still stands is someone wants it they pay. (still cheaper than from a dealer)
So if you not interested in buying the box then you can leave comments to yourself now. PLEASE.
Craig.
https://www.sau.com.au/forums/topic/104995-closed/#findComment-1936862
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
