I'll probably get a PRofec B-Spec II when I upgrade to a PFC so I can control the boost. Are they hard to install at all? I have a boost guage in my car and theres a pressure hose running from it to....somewhere (sorry I am a bit new to pressure hoses and where they go).
If its easy, would it be ok to install myself or get the workshop to do it when the PFC is being tuned?, shouldn't cost much to install, right!
cheers
Tom
https://www.sau.com.au/forums/topic/105004-installing-a-boost-controller/
East to install. There are a few threads in the tutorials/DIY section on install boost gauges and the Profec controller
Greddy Profec : Here
Boost Gauge : Here
Did you even do a search before posting!?!
with the pfc u'd have to buy a seperate  apexi boost controller (made to plug into the pfc)
and from reports I've heard, I'd say the PRofec B-Spec II  is a much better option
so the PFC hand controller itself doesn't control boost?
its a seperate unit u'd need to purchase. once its plugged into the pfc... the handcontroller then controls the apexi ebc through that
fron nengun
Brand APEXi $389 delivered
Category Electronics
The Boost Control Kit is an optional kit designed to control boost through the Power FC. Simple connection to the Power FC allows the user to access a full self-learning boost controller. The Power FC allows up to 4 different boost presets for any stage of driving. The high grade solenoid valve is the same one used in our Super AVC-R boost controller. As with the S-AVCR, the Boost control kit allows increased boost response and boost stability at high RPM's
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
