  • Replies 61
Im after one too. I just got ripped on ebay, paid the money plus courier fees to WA and the bugger nicked off :P
Im looking one for a R33 GTST, but dont want 400r, veilside or GTR copy, but thats about all you can get these days. Sucks...
your monthly expenditure would go sky high if you bought that do luck kit, and the double six rims.. :)
however i would have to touch it if you id buy it too, so damn nice!
I am planning on having the car 10 or so years (touch wood) and the kit+rims will come to around $5000 before paint and fitting B)
If I will, these are the only rims and kit that I'd get :P
Guys, be real careful buying 'cheap' kits. I, like many others, have beeen bitten badly, ie, I was quoted $1000 to fit the damn front bar cos it was so badly out of shape and in such poor condition.
I also bought a bar from a local manufacturer, and I had to get it redone 3 times before it was right - such a screw around.
It seems like you will pay either way - either pay a bit extra and get a decent product to start, or buy cheap and start saving like hell to get it fitted (then often it wont look that great anyway).
If you buy a good quality kit, it will cost alot less to fit - net result is it may actually cost less, and you have a quality finish you are happy with (eg, I bought a genuine front bar, and it fitted straight up, perfectly)
There area few places that sell genuine, such as C-red (Msport and Wise sport), team jetspeed (the qld mob, not nsw), D1 Garage (origin lab), and also, there area couple of places that do VERY good copies, such as monkey warehouse in Qld. the thing is though, the price for a good copy wont be hugely cheaper than genuine, as a good product takes time to manufacture properly.
good luck with the hunt.
got a link to the auction or his account?
normally you have to do something stupid to get ripped off on ebay, just want to see if the theory still holds.
That is the nicest looking R32 body kit I have seen in years. ( anyone know more details about this kit? )
Do any Australian suppliers stock Do Luck kits and rims?
I like the look of the Double Six rims and the T2 3 Peice Kit....
Its very discrete yet very eligant with big intakes and a sort of rear diffuser setup....
Nengun stock them for $2,500 :P
EDIT: or they used to....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
