Hey All,
My skyline came with a Carrozzeria DEH990 (35x4) head unit and a TV-XP7 and Sat Nav. The Sat Nav unit is a AVIC-G7. I cant find any documenation regarding the unit at all (in english that is). After some fiddling and research I've found that
-> Pioneer dont make an australian data CDROM for the Sat Nav unit so you can never get a map of Australia on it. Only a map of the current CD which is like Kyoto or something.
-> The TV unit is a standard LCD monitor with a Controller unit under the carpet in the passenger seat. On this unit is 4 inputs for each attenna (on the boot) and 3 RCA in's. L and R and Video. I have connected a Pioneer DVD player to this and it worked fine. The unit is a PAL based player and no problems were found at all.
-> The reception unit for the TV blows goats and I can only just get channel 9, hardcore fuzzy and scrolling. There is no option to get an Australian TV reception unit for this TV and setup. Only option would be some dodgy hack from Jaycar or an electronics freak. Doesn't phase me really. Im going to get a DVD/VCD Player anyway
I didnt expect any of this equipment to work so I didnt factor it into the price of the car at all.
Just some advice regarding the mystery Carrozzeria stuff
https://www.sau.com.au/forums/topic/10513-carrozzeria-deh990-and-tv-xp7/
I am not sure regarding another CDROM of a different brand. The CD is standard ISO9660 format and can be read by a normal PC-CDROM drive. Here are some details regarding the CDrom DISC
On the front of the DISC
NAVI MAP DISC
Road Navigator III
CNCR-303
Satellite Cruising System CD-ROM
CARROZZERIA by Pioneer
Volume in drive F is PIONEER_NAVIGATION_DISC__NAVI001
Volume Serial Number is 5894-A007
Directory of F:
26/10/1994 07:19p 285,302,784 KANTO3.MAP
14/10/1994 10:59p 373,460,012 KANTO3.SND
09/06/1994 12:47p 77,824 KANTO3.TTL
26/03/1994 03:09p 262,144 MCC94.FNT
23/10/1994 12:13p 327,680 MCC94A14.APL
5 File(s) 659,430,444 bytes
0 Dir(s) 0 bytes free
  • 4 weeks later...
  • 3 weeks later...
Guest pippen24
Youll find this is because the TV requires an NTSC input signal. Yor DVD player I'm guessing output's as PAL and wont do NTCS. If you plug in a PAL device it will come up hardcore fuzzy and really trashy. You can sometimes if your lucky see something that may resemble whats supposed to be on the screen.
The best test I did was hook up a laptop via Video OUT on the laptop to Video IN on the controller box under the carpet in the passenger side. It had an NVidia GeForce on the laptop and when output was set to PAL it came out ****ed, changed it to NTSC and it was still pretty angry, then changed it to NTSC-J and it loved it. worked fine when it was NTSC-J
my $2 worth
  • 3 weeks later...
Yeah I got one as well. The TV is kinda cool how it folds out but its all in Jap. Is there any way at all to tune Australian TV? It has the TV antennae's on the back. And does the CD player and tv work together?
For example you can change the source on the CD Player to TV and the TV pops out. Also its cool how not all the lights go on when the car lights aren't on. You turn the car lights on and everything else on the CD player turns on :P
Cool feature.... anyone know anything more what we can do with these?
Mine has like a box in the boot for it and a box under the passenger seat with Carrozzeria written on it. It seems like it's taken over the car. heh :D
Guest pippen24
Im still playing with mine. Might look at buying a DVD/VCD player for it soon for something to fiddle with. Or some crazy engine management system made by some electronics feak not sure.
Anyone know the price for a full TV/Sat Nav system with GPS tracker for an R33
I've got one for sale if anyone is interested :)
All works, just the sat nav brings up a map of japan
I've got a similar unit. Carrozzeria AVIC DR2000. Its voice activated or uses a remote. Guess what, I don't have the remote. And I don't know japanese. Arrggghhhh! Does anyone know what I can do about this? I contact pioneer australia and they couldn't help with anything. Any one have an mp3 of japanese voice commands?
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
