ok 2nd batch is all packaged up and ready to post 2moro. Posting to:
weapon of choice
sdsaibot
NIZ-26T
Shanef
Mr 32
If you want to be included in the next post out. pls pm your mailing details and we will give you our banking details. :P
Paul & Stace
P.S. we apoligise for the delay in sending out.
Edited by DiRTgarage
  • Replies 419
Posted Images
Hi,
been left off the list again, am I getting one? Maybe it will just turn up in the mail?
Thanks
Sorry for the f**k-up Sean...will have it for the weekend mate.
Um; does this disable the 4wd _without_ disabling the ABS?
Reason I ask is that a cheaper and easier way of doing this (at least on the R32 GTR, dunno about other models)
_if_ you don't mind disabling the ABS at the same time is to just kill the ignition while the wheels are turning
(i.e. while you are rolling).
You don't even need to let the motor stop rotating; use the clutch, turn off the ignition for a fraction of a second while
you are rolling, turn it back on, let the clutch out.
The 4WD/ABS disables itself till you come to a stop.
Of course, if this disables the 4WD _without_ disabling the ABS and that's what you're looking for, disregard
the above ;):D
Regards,
Saliya
i got mine today
it is a great iteam you have made up
thanks
will post up some pics of it in action so as it goes in
hehe...can't wait for that "mr"
posted today to
wannbeslida and thebuzz ....enjoy!
got mine yesterday.
gotta say its a real top level quality item, i'll find myself having alot of fun with this :O
I see in the pic you sent you have a line locker button. How hard was this to make up? and are you able to make one up for me? price too :dry:
cheers
shane
got mine yesterday.
gotta say its a real top level quality item, i'll find myself having alot of fun with this :D
I see in the pic you sent you have a line locker button. How hard was this to make up? and are you able to make one up for me? price too :D
cheers
shane
Shane...thats just the light to tell me the line locker is engaged...ive set it up so when in 2wd all i have to do is press the steering wheel button while the brake pedal is depressed to lock the front brakes.....as a fail safe, the power to the button and relay is disabled when the switch is in 4WD.....we wouldn't want the line locker activating during a run would we.
Mine arrived today, thanks Paul
Hopefully can get it fitted next week in time for the Nissan/Datsun Drag Challenge thats at Calder on the 25th.
Cheers
here you go, the switch in action
i had to cut the first part of the vid out as you could see my plates.
*warning my mate filming does swear
im only getting a word pad doc. no vid??
Got mine installed today, look forward to testing it on Saturday when I race it.
Unfortunately there wasn't anywhere appropriate at 1pm to test it out today :happy:
Edited by thebuzz
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
