  • Replies 419
Posted Images
ok new batch started
1/Jolinator
2/ttomie
3/Nismo32R
4/MikeyGTRmike
5/gun32gtr
6/jonn
7/daemon667
8/Cam
9/gtrboosting
10/
one spot left if someone wants it...must be in by end of the weekend
no worries here..cant wait to get her in....
a box of 10 "Narva" switches arrived just as i was leaving for sydney this afternoon. Ill finish them off while im away racing this weekend and pop them in the post 1st thing monday.
i could have skimped on the quality a little and bought cheap shit switch mech's but this is not my go. Narva is great quality stuff, and almost everyone who has bought one has commented on the high quality.
So with this switch you can change from 2WD to 4WD without turning the car off?, On an R32 GTR that is, if so put me down for one on the next batch and send me your account details. Thanks
yes...no need to reset ATTESSA ecu by switching car off. R32 GTR and GTS-4 only.
you can have the final one in this batch if you like...ill pm you the account details.
looms sent to...
jolinator
ttomie
gun32gtr
jonn
Cam
gtrboosting
still waiting on deposits from...
Nismo32R
MikeyGTRmike
daemon667
BlackR32
IDO 11S R32
thanks
looms sent to...
jolinator
ttomie
gun32gtr
jonn
Cam
gtrboosting
Nismo32R
MikeyGTRmike
daemon667
BlackR32
IDO 11S R32
thanks
errr??? i already transfered $50 to ur account long time ago
i even PM you the transfer details
plz check
plz check
hi Paul
i just sent u another PM with transfer details which was done on the "3rd of OCT"
plz check and let me know whats happening
thx
hi Paul....
can u plz let me know if u have received my money which was transferred to u on the 3rd of oct plz
thank you
recieved and loom sent
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
