R32 Castor Question
salad
 Share
right, so in my understanding, more castor is sposed to make your steering wheel self correct faster right?
i have an R32 with adjustable castor rods and adjustable upper arms and with these i have gotten 11 degrees castor compared to the stock 7 degrees. i did have it at 16.5 deg castor for a little bit when i put my upper arms in the wrong way and this made the wheel come back really fast in reverse, but still the same as 11deg goin forwards. also on 16.5 deg castor the steering would get really heavy after stuff got a bit hotter so i think it was puttin a lot of stress on the steering.
could the powersteering pump have something to do with my my wheel comes back slow?
has anyone else had this problem?
woah . strange post ..
well the thing with the R32's is that it runs hyrdrolic hicas on the rear wheels..
perhaps he is suggesting remove the HICAS and use the hydrolic lines that the hicas uses to run a cooler for the power steering..
just my guess from that post ... dont know if that would rectify your issue
More castor makes the steering heavier, or seen another way makes the power steering pump work harder - hence the heat build up. 16 degrees is a massive amount of castor so be careful.
Disabling the HICAS at the rear leaves the oil cooler circuit in place (There is a long post on the just recently) and will let your system run cooler. Just keep in mind the temperatures are mostly the result of the system being asked to do something unnatural....
yeah, i only ran 16.5 for a little bit cos i put my adjustable upper arms in the wrong way... <_< and resulted in LOTS of camber
runnin 11 degrees now and steering response is poor, dont like it one bit
11 degrees should b awesome dude.....i was running 9 in my 32 and 2 degrees front camber and my steering was amazing. Get rid of ur hicas and put a lock bar on, that may help maintain more fluid into ur power steering rack. have u checked ur fluid lately
yeah, steering is a bit down, gotta top it up
would it affect it if theres air in the system? is it likely there could be air in the system?
and if there is, how do i bleed it?
hahaha
nah, i think ill leave that
my speedo did stop workin for a while, so i assume this wouldve produced the same results...
anyway, the steering would be normal for a while, but then after a while of driving, the hicas light would come on and steering would become heavy, but would self correct REALLY fast, and that was with stock 7deg castor.
i would love my steering to be like this, except for the heavyness thing, it was quite heavy
 Share
    • Go to SP mufflers and get the muffler of size you want and make a nice mid muffler. It's about that simple! I have 2x 3.5 Magnaflow straight through Mufflers and while it's pretty loud with the Varex open, it's quiet enough with the Varex closed. You can also buy off the shelf Magnaflow straight through mufflers as well. You also have a turbo to quiet the car down too. Don't overthink it. Buy my extra Magnaflow muffler sitting on a shelf doing nothing (buy it new, ignore this part)
    • Centre-offset muffler under the floor, same as stock. Just....3.5". The change from straight pipe there to centre-offset will mean that you need to remake some of the pipe (add a bend or two).
    • Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome   Thanks in advance
    • Meh, whilst the Honda is a "really" good car and has potential if you want to drop coin on, it was uninspiring for me to look at, but, it did serve its purpose and is now in the boys hands, his happy, his girl is happy, as she wasn't to keen on the noisy old Patrol, and most importantly, the Minister for War and Finances is extremely happy that her "little baby boy" (6'2 nugget who is currently training to be a copper, which will make 3 coppers in the immediate "circle of trust") has a well sorted reliable car that doesn't guzzle diesel Me, I'm more than happy with the NC MX5 that I replaced it with, it's a fun little car that I like looking at, like driving, and yes..... I do like the fact that the maintenance and modifications that I have done/will do are plentiful and relatively cheap, well........ while staying naturally aspirated slow that is, and that's all I really need for a fun little daily, I can rev the 5hit out of it rowing through the gears and never really break the speed limit  In saying that wicked word, "modifications", I've already ordered something for some noise and an additional "3 ish" horse powers, or whatever it gives, in the form of a header, and, a new set of "cheapo" BC coilovers that are already sitting in the shed waiting to get put in, I had the same BC's in my old NB and found they were fine for the street, hwy, and the occasional track days I did in it, they have 6kg front and 4kg rear springs which is about 10% stiffer than the stock springs which I found worked well for their price  I've also already been in touch with MX5 Mania in Dural, so once the header is on it will get a ECUTek RaceROM tune there (I cannot rev match for 5hit, and I loved the RaceROM rev match and FFS in my old 86 "RIP") In other, maintenance news, I put some new sparkler plugs in it, and have a new set of DBA Street series pads to put in over the next day or so, I'm running the DBA street series in the SS and Honda and really like them, they work great and are not dusty at all I've also booked in a few days leave over this weekend to give me 4 days weekend do some paint correction and give the leather seats some conditioning and interior some Bissell and steam cleaning OCD lovin', the carpet and interior looks clean, but from my experience with the Bissell IRT carpet, and the steam cleaner IRT trim, looks can be deceiving I've also found that finding a detachable hard top is proving problematic, the main reason why I didn't like the NC initially was the power retractable hard top that I seen them with gave the roof line a weird look, the detachable roof though looks good, and is a same shape as a NA/NB hard top, similar, but unfortunately not the same as it has different fixture point on the front, so fitting a easy to get NA/NB detachable hard top is no bueno New Old cars are fun, cleaning, hunting and playing around brings much joy How are your beasties going? Do you still have the Skyline with the LS???, or Barra??? that you were playing with
