roflmao... J-Spec is not responsible for problems caused to relationships by the cars we supply.
As long as the credit card is free for her to use, it will be all good.
Don't you have a "REAL" job .. how the hell can you find enough time to buy 2 cars in the one week ?????
Unfortunitly I work with WiZardOz (Gary), well we sort of work
I wish you would hurry up and buy my R33 so we can turn it into a race car!
  • 3 months later...
Finally got news my car is leaving Japan and should arrive on the 30th May
It has only been about 4 months sitting in Japan waiting for a boat
I have a pile of bits waiting to go on, so I can not wait
As big Kev use to say "I'm excited"
here is a link i found i havent looked into it yet but its sposed to be able to track ships etc have a look see cos if you nkow the ships name i think this will tell u where she is .http://www.sailwx.info/shiptrack/
  • 3 weeks later...
Finally got my car today
Had it delivered this avro to my house
Will send it to compliance in the next week or 2
Need to remove a few aftermarket things first
After sitting around the docks for 3-4 months, it could do with a good clean
Need a bit of a tidy up
Small rust spot on door under RH mirror and bodykit could do with a few screws
Rear carpet in hatch area has some damage, will need to replace it
It is a fair bit different to drive than my R33 manual
Feels a bit sluggish with auto and extra weight
Will have to work on this
Let the mods begin :dry:
any that u have taken since you took delivery of it?
you can get an R34 GTR for about 60k if you import it............. :drools: ...... my dream car
No, camera is in getting repaired
What ever that thing is on the dash, someone else wanted it more
It went missing
34gtr
Me likes this one
http://www.j-spec.com.au/list/index.php?ID=6418
  • 1 month later...
Well. after nearly 6 months to the day from when I first paided for the Stagea, I went toget it registered today.
Went to get a RWC, could not get the car on the hoist due to the side skirts, so the mechanic said "Ahh, it should be fine under there"
Went to check the front lights, the front parkers were not working, mechanic said "You will get around to fixing them"
So with the RWC out the way, I went to the QLD department of transport.
Filled out the right forms, waited another 30min to get served, went out side to get the vehicle checked. the lady could not read the engine number, so I read it out for her because it was too had to read. Luckly I had rembered the engine number from before hand.
Went back inside with paper work inhand, she went thru everything, went off to talk to the supervisor and came back to tell me I needed the original import approval, not a copy.
I got staight onto the phone to IAMSHE to ask for it. Phil advised me that after doing over 600 cars in QLD they never once need the original, a copy was fine.
So it did not matter what I said they would not register it. I will have wait another 2 days to get the original and then it should be on the road.
I have been waiting 6 months now, so what is another 2 days :wave:
I had the same question asked and all I had was the copy, which they accepted in the end but in reality in the hands of whom ever you meet at the counter. I was in there for near on 2 hours while they tried to work out what they were supposed to do so I had a bit of luck I think... I waited 3 solid months for my car to get here and I would have been fuming if I had missed rego because of a photocopy or fax of an import approval (how would the car have cleared customs without that?) that sort of stuff really sh*ts me!
Hope you get it sorted soon!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
