Camshafts
Guest Nismo_Freak
What kind of gains are seen from a bump in duration and lift?
RB26DETT
Say using the 272 duration / 10.5mm lift, w/ valve springs on a fairly standard motor using only intake, 12 psi boost, full turbo back exhaust, fmic, and a HKS AVC (the fuel controller).
I would also swap the cam gears for adjustables and go with a 4 degree retard on the exhaust with a 1 degree advance on the intake.
Assuming fuel was optimized for the added airflow and tuned properly.
https://www.sau.com.au/forums/topic/10527-camshafts/
The gains are huge, it will be one of the most important factors in getting huge horsepower. Without decent cams then the potential of any turbo is not used. I would only tend to use cams like that with a bigger turbo, but even without it a 10-15% increase in power is possible.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-168818
Guest Nismo_Freak
Sounds about right I suppose... the camshafts only increase the efficiency of the motor at the higher revolutions with a slight drop at lower rpms. This in turn creates lag as noted. But the end result is more power produced at lower boost levels. The requirement for octane however goes up because the dynamic compression increases, the same when boosting more. I just needed some numbers to go by. The stock cams are as follows, I believe:
Intake: 240 duration w/ .338 lift (8.58mm)
Exhaust: 236 duration w/ .326 lift (8.28mm)
The use of the cam gears will allow me to maintain the midrange and gain back some of the boost threashold lost when I moved to the hotter cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170233
The 272's will kick in at around 4000+rpm and give the motor more legs to 8000+rpm. Something around 250 or so duration would be a better choice for a streeter. I think there are a few around 254 duration.
Most aftermaket cams need to 'dialed in' according to the motor. The factory usually designs them for a 0 deg fit but, depending on what you have done they may benifit with various timing settings.ie: don't take 4 degrees as gospel if you use non factory cams.
https://www.sau.com.au/forums/topic/10527-camshafts/#findComment-170393
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
