Hopefully the newer engine might last a bit longer before I have to build a stronger one with forgies etc. Can't wait to get it on to the track - best fun to have in your car legally! We should have a SAUSA track day at Mallala.............
Me too.
The next practice day is on the 24th Feb.
http://mallala.com/practicedays.htm
I think I can attend this one.
Are you free blue32?
Does anyone else want to go?
migh be able to make it - work is ballastic atm! Still gotta install the d-jetro and injectors + tune and then I need some track wheels.......anyone interested in some r32 gtst rims and 6 tyres to suit plus a coupla 17 inch tyres only? I'm after some 17x9 GTR offset rims and tyres for the track. Must have good clearance on the inner rim to clear the 13 inch AP brakes.......
wait till you get it 4 wheel hydroplaning in the wet ! fun.fun.fun. by the way let peter hall dyno the car. he just did my car after another one of my air meter when caput and found martin's tune to be way out in my car. ie tune with martin 263rwk and with peter 292rwk both running 1.1 bar on n1's and power fc
by the way seemed the problem was the timing. need a boost controler so i can hold 1.4 bar and should make 30-50 more kw but dont want to see gear box going bang. 292 is enough for a bit of fun anyway. anyone know if the power fc with hand controler will enable you to switch between 2 settings ie 1.1bar for regular driving and 1.4bar for [HSV i just beat one] floging or giving bikes a go. he he he
You guys were right. Got my D-jetro in and 700cc injectors today and got Martin to tune it - at first it made 291kws and then he went to lunch so I got Peter to retune it while he was out! LOL made another 20kws at the wheels after a couple of minutes in Peters hands. Very stoked with 311kw at the wheels.........
Yeh nice work........311kw in a GTR is VERY usable!
hey blue , just thought i would let you now that my car made 199rwk when it got here from japan stock. had sub zero mick and mark make my exhaust and intercooler plus pipe work and hks dumps and it dopped to185rwk put in the power fc and tune brought it back to 265rwk's on stock turbos with out upping boost. now got n1 turbos and still running standard injectors to make 292rwk's . when i get some spare cash maybe then new injectors and boost controler and then more power. what are you running, turbos etc?
Nah...........just messing with you! Martin tuned it and I'm really happy with it :lol:
Congrats on the number blue
You should wait until both Martin and Peter go for lunch. Keir will tune the car. I think that's how I got 424rwkw :lol: ....or was it Martin :D
Did you use boost 98 fuel?
Did you get Martin/Peter to compare your dynograph with the 32RB26 witb N1 turbo?
Did you get them to compare to my dynograph?
It shoudl be an interesting comparision.
BTW are you coming out to Mallala this Friday? I very sure that I will be there.
Hey guys - I am running the r34 Rb26 -
ARC bigger intercooler
blitz intake cast thingos and filters
sard 700cc injectors + regulator
Pwr FC d-jetro
Bigger fuel pump
Turbos - we figure they are N1s of some description!!! Definantly steel wheel and roller bearing with bigger exhaust housing.
Std dump pipes
std manifolds
Boost 98
Car picked up heaps of grunt across the rev range - 30ish kw at the top end but an average of 60ish kw through the mid!!!
Compared to a std 32gtr: exhaust/filters/1 bar made peak 5400N tractive effort - mine made peak approx 7000N!!! And damn it goes heaps better too.....
Friday - have to do that work thing damn it 9krpm.......but soon as I get some track wheels I'll be there! Isn't it supposed to be 35 degrees???
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
