can it affect fuel economy?
i noticed in another thread that a guy got an extra 50/100 ks to a tank of fuel by replacing his charcol cannister
my fuel economy is attrocious and i know my charcol cannister isnt hooked up . .. .
https://www.sau.com.au/forums/topic/105461-charcol-cannister/
  • Replies 77
was reading on another forum that
before i was gettin like 300, until i replaced the charcole canister.. seems to better now..
ive replaced my o2 sensor and fuel economy hasnt changed from 300ks a tank (regardless of how i drive, regardless of low or high boost)
gets slightly better with highway driving
Is the speedo correct? As Im guessing thats the only way you can tell your kms. That or you might have a fuel leak... Maybe. Done all the injector cleaning etc?
[edit]
I dont think a charcoal canister will affect things that much either. I mean mine isnt hooked up, yet Im on 535kms and my fuel light isnt on yet...
yer, speedo is correct, havent done injector clean, but will do
was really hoping the o2 sensor woudl fix economy, but its made no difference at all
strong fuel smell reversing the car up the driveway, and apparently it did have a fuel leak, but piping was repaired
cant smell fuel in the boot at all though
Could be somelike like an injector seal? Who knows dude.
But a charcoal canister has to do with the emmissions control. It is illegal to have it disconnected. Has something to do with fuel vapour or something from memory. Dont quote me on that tho.
I have the same problem with my GTT...went at most 360km full tank...haven't done anything..but I'm going for the power Fc approach..
I'll be tuning my car on the 21st...will prolly know the difference with the fuel consumption a week after..I'll keep update..
My car uses a hell of a lot of fuel compaired to other cars as well. I normally get between 300/350 city driving and 400 highway.
Even when we drove to cairns, the car still only got 400km per tank. Yes admittedly there were places where we weren't doing the speed limit... but I still would have thought that it would have got more than 400k per tank :S
yup, that sounds about the same as mine
i dont get why we are getting such bad economy, yet other skylines making more power in some cases, get much better economy
the bloody car costs me enough as it is, just keeping it on the road, would be nice to get a petrol break, and squeeze an extra 100ks out of the tank
Maybe get a PFC retune?? My new car has a PFC and I get awesome ecconomy (411ks out of 35 L :D ) The new car gets no fuel smell at all where as the R33 you could smell it all the time (Stock ECU) I think engine managment would be the main factor that effects fuel ecconomy
what power you making bunta?
retune :D
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :)
was done at mercury
Edited by Spook's_Skyline
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
