Yeah, but the question is can you ever fit 65L into the tank :P
I usually fill up before the orange light turns on, or just as it turns on. With the new fuel pump and upgrades, I'm afraid to even let it sit at the 1/4 mark - it's always above half tank.
Must get a tune soon :(
  • Replies 77
what power you making bunta?
retune :P
wifey wont like it;
ive already spent hundreds of dollars on tunes (switched exhaust, retune was another 300 on top of the origianl 600)
surely for that amount of money, it wouldnt just be a power tune :(
was done at mercury
Spooks I make 200 rwkw on the dot, However I think that having the RB25 in the lighter car (R32) would lend its self to better ecconomy, I find a lot of the time I am using around half the throttle that I used in the R33 for similar accleleration (R33 also made less power)
How could you not fit 65L into a 65L tank.
When the light comes on..you should be able to drive approx 100km more before the car will stall.
I'm just curious as to how people are measuring their distances. Surely you don't just fill it up and then read the odometer when the light come on.....that's just silly.
The only accurate way to measure the right distance is to fill it up completely to the brim and then drive 100km. Then pull into the nearest servo and fill it up to the brim again. Note down the number of litres you have put in....it's as simple as that.
The car is heaviest on a full tank so the fuel economy is its worst when the tank is full. Don't cain the crapper out of it for 100ks either, and don't baby it...just normal driving...boost it regularly. Then post up your results. I am willing to help those in need but no-one has taken me up on the offer yet.
The only reason I suggested the tune was because on my old r33 gtst I was pushing 300kms out of a tank, thanks past the light and waiting till it coughed.
Anyway I bough a SAFC and took it into Mercury for a tune and BAM gained 15rwkw and consistently got 550-600kms out of the tank!
My problem is that the skyline only get driven hard. If I was going for fuel economy, I'll just drive the office prius, it get over 1000k/tank and take 500 metres to stop from 100k/hrs. Tyre are as hard as Steel.
But if you have ongoing bad fuel eco, get a smoke test done and a good tune will fix all. but $500-750 in difference of fuel eco, buys alot of fuel. Oh wait I don't have to pay for mine.!!!
I had a similar problem with bad fuel economy and fuel smell.
I traced the problem back to the aussie fuel filler/nossle from the compliance process. seems the dodgey bastards hadnt fitted it properly and it had become slightly loose and alot of fuel was evaporating whilst the engine was running.
I simply removed it, cleaned it down and used a strong fuel rated sealant such as sikaflex. I got alot better fuel economy and lost the fuel smell.
matty
Hmm maybe a SAFC is the way to go.
I have a stock GTT and was getting 400-450kms (mixed city and freeway) before the light came on, a few months after now getting 350 to maybe 400, pure city driving though. Dont know whether this sounds right but I do know other GTT's, especially modded ones are getting more. I drive OFF boost almost 99% of the time.
So yes, Id like to know whether there is a fix for this? perhaps a SAFC might be the way to go. Ill also chuck it on the dyno to see how the figures turn out.
That's deffinetly the best way to measure your fuel consumption, i did a couple of Thursday's ago had 11 pound, 35k's highway the rest was fairly spirited, pulled into the servo and got 12.3 L i was pretty happy with that, is this more what your trying to get spook's
within the powerfc, drop the injector duty cycle down by xx %
remember, it will run leaner across the board (so more knock, perhaps?), but is the easiest way of 'retuning' it without taking it to a tuner ?
Anyway, i couldnt be bothered reading all the 3 pages, so it may help ?
Or drive it off boost. with my car i managed 450 city kms when keepin it under 0.2 bar of boost. boring as hell to drive. Mind you the other day i ended up going for a bit of a thrash and did 200kms on a tank (whoops)
oh and managed to chew up most of the fuel when i was at oran in under 100kms :P
happens when your duty cycle hits around the 92% mark on 700cc injectors
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
