Heya all,
Just wondering what the quickest and cheapest way to 170rwkw is, bearing reliability in mind (as much as possible for an R32!) I think that's more than enough power for a 32, bearing in mind they come stock with 160kw at the motor!
Mine is pretty much stock now, power-wise, save for a catback exhaust and Apexi filter insert, and it already goes alright. So I think such a power-jump will be more than enough (being sensible about things).
I think the following would fit the bill:
3" Front Pipe and Dump Pipe (Probably the 'Flying Performance' style 2-in-1 job).
Standard Cat Convertor? (Do I need to change to hi-flow?)
3" Catback Exhaust with Turbo Muffler
R33 Turbo (Rebuilt)
Electronic Boost Controller (eg. Greddy Profec-B Spec II)
Fuel Computer (eg. Apexi SAFC-II)
Fuel Pump (eg Bosch 040)
Sports Intake Filter (Filter Insert in Stock Airbox)
Front Mount Intercooler (probably just a Hybrid Kit).
Let me know your thoughts on what else is needed, or on what is not needed, as you think fit. I think it's pretty spot on, but I figured the skyliners out there that are already pumping 170kw at the wheels would know better than me :P
Thanks,
Adrian.
  • Replies 46
That should just about do it. You can get away with just a regular old 3 inch cat as opposed to the metal cats.
There won't be a hell of a lot left in your injectors but it's easily do able.
To save a bit of money you could go a bleed valve.
Id also recomend a dr drift chip over an sfac, would be about the same price but its one less bit of gear for someone to nick out of your car, and its probably a better tune, plus takes off speed cut and boost cut etc.
And get a fuel regulator. That will give the injectors that bit more they might need.
To give you an idea I have just a front pipe back exaust, fuel reg and pump, pod with cold air, bleed valve set at 12psi and a dr drift chip and im making 155rwkw.
If you add the fmic, dump and r33 turbo (id say even not hiflowed) you should easy get 170rwkw.
from 160rwkw to 170...I think a boost controler is enough....just don't boost higher than 1 bar...0.9 shuld get that power already
umm you got 155rwkw? I thought Johny said stock has 160rwkw?
Edited by SKY 34
i got 170 with a 3" turbo back exhaust (no cat), r33 turbo, gtr fuel pump, hks pod and 1 bar boost
stock ecu and stuff, have remapped now.
with remap should get over 170 pretty easily, if you change your afm, my afm is now maxed out...
highly recommend dr drift
adja, u know the recipy....follow wat i had on my car and ul love it dude
Hey Nathan! What happened with that 33 you got? Surely you're not gonna get it on the road, it's too crazy.
Well, after hearing all the comments, I think the following is necessary to SAFELY provide for 170rwkw:
Fuel Pump
Fuel Pressure Regualtor
Air Flow Meter
Pod Filter Intake
R33 Turbo
Front Pipe
Dump Pipe
High Flow Cat
Catback Exhaust
ECU
Boost Controller
Now I'm thinking this is all gonna cost a lot more than I wanted it to. Oh well, might have to do it a bit at a time. Save the boosting for last... see how I go.
Thanks for all your help,
Adrian.
Is this close enough to 170kw for you? :P
mods to get there are:
Flying Performance 3" Front/Dump Pipe
3" High-Flow Cat
3" Kakimoto Catback Exhaust
K&N Pod Filter
Custom Heat Shield
RB25 Turbo with RB20 Actuator (increases base boost by around 3psi)
R34 GTT Sidemount Intercooler with Custom Piping
D2 Fuel Pressure Regulator
Walbro 255 Litre/Hour Fuel Pump
Turbotech Boost Controller set at 11.5psi
ECU Tuned by Dr_Drift
3" High-Flow Cat
K&N Pod Filter
Custom Heat Shield
You're my hero! That's exactly what I wanted to hear. Now I just gotta make up my mind as to whether I spend the extra $3000 - $4000 to get all of those mods.
Thanks again,
Adrian.
hey
i have a pod cat bak zorst boost controller bov and i make 173kws at rear wheels
That doesn't sound right. Maybe you've already got an aftermarket turbo kit fitted or something. That, or you're running WAY too much boost, and your motor is going to pop open any second. I can't see the bov making much difference.
Either way, I don't like it.
VG30
fuel pump
fuel reg
HKS FCD
pod
zorst
fmic
target 3g's or less
How come VG30? Isn't that the older turbo from the 3 litre that was used in the VLs? I would have thought the turbo from the R33 would be a better choice. Maybe I'm wrong.
I was thinking that for only 12psi, I could get away with stock turbo.
Guess not.
I'm thinking that if I stay at 12psi I can use the stock RB20 turbo, which will save mucking around. Also want to keep the stock airbox, as I've already got an Apexi Power Intake Filter insert in it, and don't wanna switch to a pod filter if I can avoid it.
Thinking to do:
FLYING PERFORMANCE 3" Front and Dump Pipe in 1
3" High Flow Cat (eBay job)
HYBRID Front Mount Intercooler Kit
BOSCH 040 Fuel Pump
Fuel Pressure Regulator (not sure which brand yet or where to get one from)
APEXI SAFC-2 Fuel Computer
GREDDY Profec-B Spec 2 Boost Controller
Should cost me around $2500 in parts, then obviously whatever installation and tuning costs in addition. If I can get over 160rwkw I'll be happy, but the magic figure is 170! :rolleyes:
Stay tuned...
Guess not.
VG30 turbos come from Z31 300ZXs
they have a bigger exhaust housing so can flow more exhaust gasses and therefore make more top end power
these are known to be pretty laggy on rb20s though as the exhaust housing is designed for a 3L engine not 2L...
but then again, some people dont mind the lag and are happy with the power gains
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
