Cleaning out my garage and have heaps of crap sitting around:
3 x RB20DET engines no turbos or loom, sell whole or parts $350 each
1 x RB25 NA bottom end $100
1 x SR20 NA bottom end with alternator and starter motor $200
R33 2WD Engine crossmember $100
Also have my RB30DET project, RB25 VVT head, turbo oil pump, new 20 thou oversized NA style race pistons to maintain compression, Linished and balanced rods, 1.2mm metal head gasket, all new gaskets, bearings and seals. block and head bathed and fully prepped, no turbo or exhaust manifold, can supply standard turbo manifold. Also has chrome harmonic balancer and water pump pulley and crank angle sensor bracket. Engine is not yet complete i still have to plug up the VVT and install pulley for the timing belt. I am happy to finish the engine before sale or you can buy as is.
Selling this engine as i no longer have the car it was for and i'm starting a new project.
$3500
I'm located in Newcastle
https://www.sau.com.au/forums/topic/105614-heaps-of-stuff-engines-parts-etc/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
