G'day, ive got an r32 gtr with the following mods, what should be my next upgrade, im guessing turbos as these fuel systems are good for around 400rwhp correct?
Apexi full adjustable computer
3.5" exhaust from turbos back
Blitz EBC
pods
thicker intercooler
exedy hi performance clutch (very heavy clamp load)
I'd be looking for around 400hp at the tyres without pushing it too hard.
The car made 226rwkw (308hp) @13psi with a mines computer and it was just before the bottom end let go, now has a fresh rebuild.
Also any approx pricing would help.
thankyou
Brad
https://www.sau.com.au/forums/topic/105630-the-next-step/
injectors are good for around 400 engine horspower (with a fairly fat tune).
i would not think you can safely get to 400 rwhp without upgrading the injectors, and the fuel pump. considering you've already been through the rebuilding process i wouldn't want to risk it without them.
for me i reckon the limit on the stock 32 GTR stuff is around 260 or 270 rwkw.
i reckon next step power wise should be:
injectors and pump
cams
turbos (something like R34 N1s, or GTSS or 2530s)
do it all at once, retune and away you go.
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1944820
by this do you mean the turbos will push 260rwkw?
I also forgot to mention, it has a nismo adjustable fuel reg
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1944834
sorry i meant stock fuel system, and stock turbos being looked at together. but yeah, stock turbos are not good for much more than 260 or so in my experience. perhaps with cams etc you could get to 270 or 280. injectors will be marginal though at that level.
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1945355
Cut to the chase :
TO4Z
Forged internals
Upgrade fuel sys
cause everyone has a lazy 10k sitting around.
Nugget, you will get 300rwkw with stock injectors.
Ferni is making 300rwkw with GT-SS and stock injectors.
But that is the limit of them.
I wouldnt reccomend bumping the rail pressure (with that fuel reg) to be honest.
GT-SS (my thoughts) are the way to go if its a street car, with a fuel pump and injectors you'll get into the 320-330rwkw mark,
Will get you into the 11's aswell i believe
Why type of rebuild ? (i cant rememer your post on CalaisTurbo about it all)
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1945682
yes, i'm sure 300rwkw is possible on stock injectors and pump, but on a 10 year old + 32 GTR i wouldnt think it's a good idea. i would definately upgrade if you are doing turbos.
the advice is sound though about doing the SS and turbos etc, but i must say i'm blown away by the 240rwkw before 3000 rpm!!! that i would like to see. i've never seen any 2.6 litre RB26 come close to that power at 3000rpm, but i am intrigued as it would be awesome. and more details on this motor?
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1946159
Ah, fuel pump for sure, wasnt disputing that at all, totally agree on it.
Its ferni's... most of the other GT-SS guys are making that aswell...
Or maybe it was 10psi on before 3000rpm, oh god... ive got myself into confusion again ;)
i'll edit the post, i cant damn well remember at the moment, dont wanna confuse anyone else
"unless" im mistaken, which is highly likely... either way... its solid respons regardless of how you look at it heheh
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1946202
haha yeah, 10 psi at 3000 sounds more like it. 240rwkw at under 3000rpm would be mind blowing! i'd be shifting up at 4000 all day long ;) lol that would be a farking quick GTR.
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1946339
it was just a standard rebuild
so your limited as to how far it can be pushed... thats ok, GT-SS fall into there quite easily (worked out im a fan of em yet? ;))
you might not need cams right off, i'd see how you go first
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1946549
well i have about that now. stock turbos at 14psi, power FC, cam gears and a cat back exhaust (at the least) will get you there with a good tune of the PFC and the cam gears.
https://www.sau.com.au/forums/topic/105630-the-next-step/#findComment-1946903
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
