NGK IRIDIUM IX Spark Plugs BKR6EIX-11, $13.70 per plug/ $82.20 set 6
These spark plugs are brand new, part of a group buy I ran.
Payment is by direct deposit/transfer to my acct. I am located in Thirroul (near Wollongong) and pickup is fine if that suits you.
Cheers,
Caz.. :)
acct details:
ANZ
Caroline Felgate
BSB: 012593
Acct; 5654 13726
email: [email protected]
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
