Pod Box....Really..WhY?
  • Replies 62
UAS has two boxes to encapsulate your pod. There is one made of fibreglass for $195 and for ultra wank :whackit: they have carbon fibre one aswell.
Look in "parts and accessories " -> "Skylines" -> "Engine Clutch And Gearbox Components"
http://www.uniqueautosports.com.au/
OR
You can just make your own turbo partition like they have on the above site aswell.
I cant believe people dont know about this. I am thinking of setting up a web site with photos of the way i installed my front mount intercooler, pod filter, etc and the little things that go with it all like thermal wrapping the dump and partitioning the pod filter, how to pipe the intercooler, cold air feed, etc because not enough people are doing this.
At the moment i am toying with the idea of installing some cosworth vents in the bonnet (facing backwards close to the back of the bonnet) because of the tremendous amount of heat trapped under the hood. The problem is of course making it so that water wont drip onto essential components under normal conditions. If anyone out there has suggestions for more subtle and as effective vents to stick in the hood i am all ears. Note anyone that tries to suggest something like mounting a subaru bonnet scoop will be hunted down and shot......
Again for the people who dont remember physics "HOT AIR RISES" and with no where for it to go under the hood it will simply soak into your engine ie "HEAT SOAK" as a result you may get pinging and your car wont perform as well because the intake charge is heated by every component of the engine before it reaches the combustion chamber
R33NT:
You have raised some good points. For a n00bie .... what sort of instruments could I get that tell me temperatures of certain components?
I'm not a fan of 'gauges' so I'd prefer a digital screen/readout.
What components should I be keeping an eye on ?
Im all for maximising power out of my current engine setup and I know that like the pod airbox giving a cold air intake keeping engine temperatures at a decent level will also increase performance/life of an engine.
I had looked at raising the bonnet but i didnt like that idea because it would mean the firewall would get drenched every storm we had. I know the engine bay is water proof to some extent but i dont like the idea of pouring bulk water over an area of the engine bay that wasnt designed for that. Note we get serious storms up here in the NT, the storm usually last 4 months and it is called the monsoon.
Carbon fibre bonnet! to much of the ol' :whackit:
Benm i may be a newbie to this forum but i have had my GTS25t for over 3 years and i am an Engineer (bought it when i finished my degree's). As such i crave all the knowledge i can manage about my car and i have had 3 years to do it. Anyway i stumbled across this forum by accident when looking at a link from skylinesdownunder.
I am usually on the ford performance forum (nick = skyline) annoying everyone there. I took an XR6t for a test drive a while back and went on the above forum and gave it a rough review. It was hilarious to see how many people responded asking why nobody had criticised it before. Below is a link to my finest hour.
http://64.4.22.250/cgi-bin/linkrd?_lang=EN...ncefalconsforum
I would have thought a box would be best. because otherwise you are relying on the top of the bonnet to seal the top part of the partition.
Benm as for gauges i only use the stock gauges with a small HKS boost gauge (came with the car) mounted under my head unit. I had thought of getting a pillar mount twin gauge type setup which would house my boost gauge and one of those autometer air fuel ratio meters. You will find that a humans are better at reading a gauge at a glance then reading a digital display using something like 7 segment readout.
Jay95R33 do you have templates for your box?? If so could you email them to me at
[email protected]
Thanks
[email protected]
Thanks
Yepp no worries.
I've got the templates at work in Word and JPG format. I'll email it out to anyone that want's it on Monday :uh-huh:
J
a31_cefiro: I have that issue thanks anyway. i have read it a few times and will probably do something similar! Do you haapen to have the first installment of the 34 project? I have all of the others except for the very first one! very useful info for me...
R33NT: dude, read my earlier post, i already know that the pipe can collapse and why...i have bought a pod but want to make / buy a cold air box for it before i use it, i have read the article and also will be changing the ribbed condom in due course - similar to the hpi 34 project car. Oh yeah and i like the pod noise but its TOO loud, i dont want that much attention, and changing gears less than 2000rpm just to keep it quiet is not my idea of driving :D
Hi guys, I use the $40 digital temperature probes and displays from Jaycar for doing this sort of stuff on road cars. I have one in the cold air box, one on the compressor outlet and one just before the throttle body. The passenger reads and writes down the numbers for review later.
You could do it with one and move it around, that would cost less but be a little less convenient.
On the race cars we use the temperature probes on the Pi or Motec data logging system. No passenger required.
We have found no real temperature differences between having a lid and not having one when the car is moving. When stationary the lid does make a bit (not a lot) of difference but as soon as the car moves and air flows in through the vent and pipework the temperature returns to ambient.
Hope that adds to the discussion.
I've got one of those too. Thy seem pretty good for the $$$$.
Just wondering how you go when using them, cause the lead to the probe isn't long enough to bring the display into the cabin.. Do you just leave it outside???
Also, when you mount it in, do you just wedge it under one of the pipes and crap it up tight??? I was always paranoid of doing it this way !!
J
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
