Fujitsubo sounds good.. look at the muffler on Fujitsuybo blaze
http://www.fujitsubo.co.jp/mc-prod/
sad that thye produce this for waggons only...if only I can get the cat back pipe for power getter and this muffler
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-1958811
Recommendation? Find a local exhaust dude who knows what he's doing and save yourself the cash!!! Seriously.
Well I'm going to have to look a bit harder then at the locals. I went to Exhaust Technology here in Adelaide for a cat back system for my 33 & they wanted nearly a grand for mild steel! But I want stainless which from them (with a JunBL muffler) costs a whopping $1577!
I'm sure it's be a nice system if I had it done, but doubt it's really worth that much, even if they do use 309 (High Platnum they claim) stainless steel.
I've seen on NENGUN a Greddy Titanium system for less than $1200 delivered. Only problem I have is that I really want a twin pipe outlet. I'm yet to see a bolt on system that's twin pipe for a 33.
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-1959973
huum...so you suggest me go into exhaust shop, no need research and believe whatever the guys has to say?
nyways...good to hear that blitz NUR spec is loud~~
I'm abt to get a second hand Nur....thanks for everyones help..
btw is the exaust side mount? <---- slanting
Edited by SKY 34
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-1960155
No, not suggesting that at all, find a local who knows what he's talking about, make sure you know what you're talking about and tell him what sound-style you're sorting after, just do the shop. Speaking from experience here.
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-1960378
yup yup~~ well I got to ask around in forum for other ppls opinion before I have an Idea what I'm talking abt~~..I don't have any friends who has these exhaust on...at all...
Mate, you wanted an opinion. I gave it to you, up to you what you do with it. Tell me what I am to gain from giving false or bogus information to people who are asking genuine questions and expecting genuine answers? Don't agree with what I have to say, fine no skin off my teeth Hmm? But why warrant a reply that's going to cause conflict when clearly nothing need be said? Is it to stir up petty bulls*it and ridicule those to whom you've asked their opinions? Or is it because you drive a magna?
Apparently personal experience accounts for nothing...
No need for the remarks mate. Try to be nice to the people whom you seek help.
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-1962504
Well, your opinion is…go to a shop and ask…and you must know what is going on..
I din’t say your comment is bogus...just that I don’t know what is going on and I don’t know which one is a good shop…so I had to ask in forums for ppls opinion… a while after I wrote the post someone was selling a second hand Blitz Nur spec…and since most ppl agreed that the xhaust is great and loud so I’m going for it…I’m not ridiculing your opinion
I appreciate your help on the Q45 TB and your opinion for the xhaust
Nyways this is off topic already .. I already got my answers .. thanks for help guys~~
Edited by SKY 34
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-1962733
  • 7 months later...
If I want to eliminate a cat and istall my XS downpipe dual wastegate what is involved if I have an HKS cat back existing?
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-2538677
If I was you (and i was in the same situation not too long ago) I would get an xforce 3" turbo back exhaust with 4.5" tip. I got it fitted for $990. Both the tip/cannon and the cat (high flowed) are stainless steel while the rest is mild steel. It sound very nice but is not too loud and gave a noticeable gain over the previous 3" cat back crap exhaust that was on before.
https://www.sau.com.au/forums/topic/106171-catback-exhaust/#findComment-2541217
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
