Other kits are going to be displayed soon. I offer a 12 month gaurantee on all my engines BUT everything is to be done my way and no short cuts. I will discuss warranty with each and every customer.
All kits up to 650-700hp will cost roughly the same as the PK400 requires a little more setting up to adapt the 'smaller' turbo.
Any parts that you may already have can be retained and the price will be adjusted accordingly.
Basic Engine Rebuild (BER)
This includes rings, bearings, all block work and minor head work, new timing belt, all new seals and gaskets, new head bolts, new exhaust studs + nuts, and labour.
Engine: RB20DET + RB25DET
$2950
Thats fcking awesome price mate! If anything goes bang Ill look you up!
Just realised you in Queensland, oh well should be up there next year living so yeh...
Awesome prices and an awesome mechanic!!!
Dan's given me a kick ass price no-one will ever beat on a gt30r turbo and fuel system upgrade. Made other quotes from a few places in Brisbane look like a joke.
Dan done work for me before including upgrading my suspension and installing misc items and did a great job!
I highly recommend Dan for any and all your upgrade needs!!!
hey dan,
that clutch is working a treat.
i will be wanting a rebuild soonish, so you will be getting the job.
but ill talk to you then.
ill have a sticker on my car, and ill put the word around as well.
hey, do you do any installation and tuning of a power fc at all?
If you wanna drive round to my house I'll install it for free. (non D-jetro that is lol)
I cannot do the tuning of the PowerFC yet but I will eventually. I can do Microtec and Haltec to a certain degree but still have to master the finer points. PowerFC is definately on the to-learn list. I should be able to pick it up very easily.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
