Other kits are going to be displayed soon. I offer a 12 month gaurantee on all my engines BUT everything is to be done my way and no short cuts. I will discuss warranty with each and every customer.
All kits up to 650-700hp will cost roughly the same as the PK400 requires a little more setting up to adapt the 'smaller' turbo.
Any parts that you may already have can be retained and the price will be adjusted accordingly.
Basic Engine Rebuild (BER)
This includes rings, bearings, all block work and minor head work, new timing belt, all new seals and gaskets, new head bolts, new exhaust studs + nuts, and labour.
Engine: RB20DET + RB25DET
$2950
Thats fcking awesome price mate! If anything goes bang Ill look you up!
Just realised you in Queensland, oh well should be up there next year living so yeh...
Awesome prices and an awesome mechanic!!!
Dan's given me a kick ass price no-one will ever beat on a gt30r turbo and fuel system upgrade. Made other quotes from a few places in Brisbane look like a joke.
Dan done work for me before including upgrading my suspension and installing misc items and did a great job!
I highly recommend Dan for any and all your upgrade needs!!!
hey dan,
that clutch is working a treat.
i will be wanting a rebuild soonish, so you will be getting the job.
but ill talk to you then.
ill have a sticker on my car, and ill put the word around as well.
hey, do you do any installation and tuning of a power fc at all?
If you wanna drive round to my house I'll install it for free. (non D-jetro that is lol)
I cannot do the tuning of the PowerFC yet but I will eventually. I can do Microtec and Haltec to a certain degree but still have to master the finer points. PowerFC is definately on the to-learn list. I should be able to pick it up very easily.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
