To add to the already vast amounts of praise Daniel has received for his mechanical efforts, I'd like to say that he did an excellent job in doing my timing belt/water pump/other misc items, really seems knowledgable and skilled in what he is doing, goes above and beyond what is required for the job and does it all for a reasonable price. I'm a tough customer to please and he passed with flying colours :P
  • 9 months later...
I would have to add, that Dan has done an excellent job on my motor rebuild with the best competative price arround in brisbane, with very high dedication and also skill. I would have to recommend to all who are after any mechanical needs or motor rebuilds to give him a call
Thanks Mate
Adam
the clear coat over the gold really made that engine look sweet but pain in the asss putting it back in wiht the low mount turbo setup but he managed to get it done :D did dan change the oil on sun??
I think dan is the best thing since sliced bread, he has done an excellent job and when things didnt go quite as planned (though no fault of his own) he has been there to help. i recommend dan to anyone that will listen and quite a few that wont listen.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
