ok so i now know that there are 3 or 4 diffrent auto trans missions avable in the 33 range
i just bought a 33 box off here and found out its a 5sp auto
as of the extra unit on the rear, just off the extension housing, and the fact at a guess i have P...R...N...D...3...2...1 in sted of just the P..R..N..D..2..1 as the 4 spd boxes have and also the trip tronic r34 auto's
my main question is i have tried a r34 trip tronic yolk and its the same size as my olf rb30e auto yolk, as in the rb30e auto will accept the yolk with a nice and smoth ristance just like they are ment to be, ok so that works out my friend but im still stuck, im stuck because the yolk i need is bigger in the splinds and also im guessing over all size
so out of the r33 autos what part no's are the yolks, or if anyone has a tail shaft for a 5sp auto can i buy it off ya
is it the same as a manuel, if so i might get to me mates r33 tomie and steel his, lol just kidding
any one got any clue
https://www.sau.com.au/forums/topic/106664-r33-autos/
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
