Hey guys i need standard R33 wheels in order to pass regency inspection.
Only need to hire for 2 weeks or i'm willing to purchase a whole set.
They dont need to have tyres on them.
If anyone has a set they no longer need, please pm me
This is urgent!
Thanks guys and gals!
https://www.sau.com.au/forums/topic/106704-r33-standard-wheels-wanted/
Not ideal i know, but I have 2 you can borrow for some sort of security, be that a deposit or someone i know & trust well enough on here vouching for you.
Let me know.
P.S. I normally run under the account "Oosh", but am having technical difficulties, so you know i haven't just blown in here.
Edited by Oosh2
Awsome
can both you guys pm me your contact numbers and i'll get in touch with you this week some time, as i need them asap.
You will get the wheels back with brand new tyres on them, as i have already paid for this as part of the compliance expense.
Hope this will cover your inconvenience?
Thanks guys
Edited by Tommmo
I gotta get through regency also, I dunno if standard R34, 17 inch rims will do but if you need them you can use them first, coz I don't have my inspection till March 21st
I got a mate who does all the compliancing so if you need anything else let me know.
Yeh that sounds about right, however Best Enterprises told me it would be best to have standard wheels, as sometimes regency can be real picky about the smallest crap! (as i'm sure most of us have experienced first hand)
and in the end they dont want any hassels and i surely dont either, so i think its best to keep them happy.
thanks for the suggestion though.
Don't think you even need standard wheels.........I believe(correct me if i'm wrong) if they are no more than 2 inchs wider and/or higher and not sticking out the guards, your all ok!!
I suggested the same thing to them, i was going to use wheels of my GT-T, however they werent interested. Dont ask me why?! ;)
Thanks for the offer though
Awsome
Thanks guys
Sounds more than fair. PM on its way.
thanks guys i'll get in touch with all of you today or tomorrow
Ive got standard 16inch Stagea rims, same size/profile as Skylines, and Ive seen R33's on auction sites with these rims on.
New tyres as well, want to sell so I can grab some 17's.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
