  • Replies 389
Posted Images
she grips only when i want her o though
preferably just before large chuncks of concrete
hasnt always worked out that way though has it my friend? lol
that was a bit harsh.
tree 1, fatz zero
concrete 1, fatz zero
ex girlfiend 1, fatz zero
i just have no luck with cars
at least it was only a silvia that bit the concrete. good riddance i say. that engine got a chance to shine in a real car after that.
I really wanna come bob,
But im getting payed monthly now... I get payed on wednesday and its all gone + some as i preordered my xbox360,
What is the latest i can pay? Also being an SAU NSW Member i have a cams licence dont i?
Hey guys,
Get your payment in ASAP... this will be a top day that all can enjoy, I know I'm putting my name down, the car WILL be ready by then, so come on out and have a blat with me!
This day will be fantastic for all levels, from beginners to full race car's (all in different categories of course). And we can have a good old friendly time battle with the rotor boys and girls also... that is always some fun :)
If we are lucky the boys and I might get a chance to go for a drift sometime and smoke some serious rubber only inchs away from each other...
Be there or be square kids!
Dan.
Oh man, I really really wanna be in for this, but I've started having alot of trouble with cooling lately, and its put me back alot on getting the front mount :P
I may have to just come down to spectate, at least then I can check things out before I do em.
I sooooo wanted to start doing track days this year though :(
The day is structured in groups that go out together one every 10 seconds from the pits - not a grid. The groups will be of cars that are doing similar lap times.
Last track day we did two car sprints in the middle of the day for 5 laps which was fun and I think we are doing this again if there is enough interest.
Mr Plunk - perhaps you could start a thread for us to help you with your cooling problems.
Jay - we are always willing to help out newbies. We want you to be addicted to the track like us. :mad:
There is no test for the licence.
You need a helmet.
There are a few threads on here about getting your car ready for the track but we can easily tell you the basics when it gets closer to the day.
Also, one of the more experienced and level headed guys will be coming out with you on your first laps to give you pointers on saftey and how to get the most out of your car.
There are not many track days better for newbies than SAU/RENEW ones but the fast guys still get free rein in their group.
Does that help everyone?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
